Ana içeriğe geç
PDP Afterglow Fener LED Replacement
Neye ihtiyacın var
  1. PDP Afterglow Fener LED Replacement, LED: adım 1, 3 resimden 1. PDP Afterglow Fener LED Replacement, LED: adım 1, 3 resimden 2. PDP Afterglow Fener LED Replacement, LED: adım 1, 3 resimden 3.
    • Gently pull off your left and right ear pad. For further instructions on how to carefully do this please go to this guide here.
    • For each of the red circled screws, take your J000 screwdriver and unscrew the screws.
    • This is a picture of what your headset looks like now that you have done the first two steps and have removed the part that you unscrewed.
  2. PDP Afterglow Fener LED Replacement: adım 2, 2 resimden 1. PDP Afterglow Fener LED Replacement: adım 2, 2 resimden 2.
    • First remove the battery from the headset, for instructions on how to do this correctly go here
    • Now take your J000 screwdriver and unscrew the screws that have a red circle around them.
    • Now remove the circuit board from the headset and flip it to the other side to be able to see the light/LED.
  3. PDP Afterglow Fener LED Replacement: adım 3, 3 resimden 1. PDP Afterglow Fener LED Replacement: adım 3, 3 resimden 2. PDP Afterglow Fener LED Replacement: adım 3, 3 resimden 3.
    • Take your helping hand with alligator clips and put the printed circuit board on it.
    • This picture is a close up of the LED with the highlighted areas you need to unsoldered.
    • Now take your soldering iron and unsolder those four highlighted areas.
    • Your LED should come loose and you can now put on your new LED.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Thomas Williams
512 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 üyesi
UMASSD-GULBRANDSEN-F15S5G3
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 866
