Ana içeriğe geç
PDP Afterglow Wired Xbox 360 Controller Button Replacement
Neye ihtiyacın var
  1. PDP Afterglow Wired Xbox 360 Controller Button Replacement, Case: adım 1, 2 resimden 1. PDP Afterglow Wired Xbox 360 Controller Button Replacement, Case: adım 1, 2 resimden 2.
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. PDP Afterglow Wired Xbox 360 Controller Button Replacement: adım 2, 1 resimden 1.
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. PDP Afterglow Wired Xbox 360 Controller Button Replacement: adım 3, 1 resimden 1.
    • Remove the top cover from the bottom and place next to each other.
  4. PDP Afterglow Wired Xbox 360 Controller Button Replacement, Button: adım 4, 1 resimden 1.
    • Remove the rubber button covers from the A, B, X, and Y buttons.
  5. PDP Afterglow Wired Xbox 360 Controller Button Replacement: adım 5, 2 resimden 1. PDP Afterglow Wired Xbox 360 Controller Button Replacement: adım 5, 2 resimden 2.
    • Push up on the buttons from the front and pull them out from the back.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Joi Officer
298 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-1, Harley Fall 2015 IUPUI, Team 3-1, Harley Fall 2015 üyesi
IUPUI-HARLEY-F15S3G1
4 Üyeler
5 adet Kılavuz yazıldı
4Kılavuz Yorumları
What about removing the Dpad? i really need help.
Elijah Douglas - Yanıt
I’m sorry but, I have to say that the reassembly process is harder than simply ‘follow the instructions in reverse’; if you try and place the half with the buttons, the buttons fall out or end up misaligned ; and if you use the other half, the rubber covers and the tumblers will fall out.
Again, this guild comes off a little too simple, there’s more to it.
Christopher Mali-Martinez - Yanıt
the circuit board comes off the other half. You can stack them very easily. You're simply incorrect.
Tyler Anderson -
No not really I agree with homeboy cause I just took mine apart to fix drifting and the one piece clip for RB and Lb doesn’t just fit in there right
David Drinkard - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 66
Her zaman: 6,070
