Ana içeriğe geç
PDP Afterglow Wired Xbox 360 Controller Cable Replacement
Neye ihtiyacın var
  1. PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Case: adım 1, 2 resimden 1. PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Case: adım 1, 2 resimden 2.
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: adım 2, 1 resimden 1.
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: adım 3, 1 resimden 1.
    • Remove the top cover from the bottom and place next to each other.
  4. PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Cable: adım 4, 2 resimden 1. PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Cable: adım 4, 2 resimden 2.
    • Remove the logic board by lifting up on the logic board and pulling out.
  5. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: adım 5, 1 resimden 1.
    • The cable connects to the logic board with a white connector. Above the right joystick, there are four solder pins labeled GND, VCC, DM, and DP.
  6. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: adım 6, 1 resimden 1.
    • The soldering iron is very hot and can harm you or the device if used incorrectly.
    • Desolder the four pins.
  7. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: adım 7, 1 resimden 1.
    • Using your new cable, solder the white connector to the logic board. Be sure to have the cables facing towards the inside of the logic board.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Jayson Norcross
283 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 3-1, Harley Fall 2015 IUPUI, Team 3-1, Harley Fall 2015 üyesi
IUPUI-HARLEY-F15S3G1
4 Üyeler
5 adet Kılavuz yazıldı
4 Yorum
where can I find a replacement cable to perform this precedure with?
Aaron English - Yanıt
yes!! i would like to know too.. i have been searching for long time for that cable
sokratis162 -
Android cable
Wayne -
U can use a old Android cable
Wayne - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 52
Her zaman: 6,843
