Ana içeriğe geç
PDP Afterglow Wired Xbox 360 Controller Case Replacement
Neye ihtiyacın var
  1. PDP Afterglow Wired Xbox 360 Controller Case Replacement, Case: adım 1, 2 resimden 1. PDP Afterglow Wired Xbox 360 Controller Case Replacement, Case: adım 1, 2 resimden 2.
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. PDP Afterglow Wired Xbox 360 Controller Case Replacement: adım 2, 1 resimden 1.
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. PDP Afterglow Wired Xbox 360 Controller Case Replacement: adım 3, 1 resimden 1.
    • Remove the top cover from the bottom and place next to each other.
Sonuç
Aaron
103 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 3-1, Harley Fall 2015 IUPUI, Team 3-1, Harley Fall 2015 üyesi
IUPUI-HARLEY-F15S3G1
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 21
Her zaman: 1,315
