Ana içeriğe geç
PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement
Neye ihtiyacın var
  1. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement, Joysticks: adım 1, 1 resimden 1.
    • Remove the two 11 mm screws from the back of the controller using a Phillips #0 screwdriver.
    • Remove the five 8 mm screws from the back of the controller using a Phillips #0 screwdriver.
  2. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: adım 2, 1 resimden 1.
    • Remove the back cover from the controller and set it aside.
  3. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: adım 3, 1 resimden 1.
    • Remove the circuit board from the front casing.
    • Be cautious of disconnecting the vibration motors which are attached by thin wires.
  4. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: adım 4, 3 resimden 1. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: adım 4, 3 resimden 2. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: adım 4, 3 resimden 3.
    • Wiggle and pull the joystick until it comes off of the circuit board.
  5. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: adım 5, 2 resimden 1. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: adım 5, 2 resimden 2.
    • Place the new joystick into position and press until the joystick makes a click.
  6. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: adım 6, 1 resimden 1.
    • Place the circuit board and vibration motors back into the front casing.
  7. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: adım 7, 3 resimden 1. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: adım 7, 3 resimden 2. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: adım 7, 3 resimden 3.
    • Place the back cover into position.
    • Reinsert the two 11 mm screws into the back of the controller using a Phillips #0 screwdriver.
    • Reinsert the five 8 mm screws into the back of the controller using a Phillips #0 screwdriver.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 23
Son 30 gün: 83
Her zaman: 2,661
