Ana içeriğe geç
PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement
Neye ihtiyacın var
  1. PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement, Case: adım 1, 2 resimden 1. PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement, Case: adım 1, 2 resimden 2.
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement: adım 2, 1 resimden 1.
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement: adım 3, 1 resimden 1.
    • Remove the top cover from the bottom and place next to each other.
  4. PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement, Vibration Motors: adım 4, 2 resimden 1. PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement, Vibration Motors: adım 4, 2 resimden 2.
    • Lift the Logic Board and remove the rumble motors from the base of the controller.
  5. PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement: adım 5, 1 resimden 1.
    • The rumble motors are located in the bottom right and left hand corners of the controller.
    • Find where the power (red) wire and ground (black) wire are connected to the logic board. The power (red) wire should be on the left while the black (ground) wire is on the right.
  6. PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement: adım 6, 1 resimden 1.
    • The soldering iron is very hot and can harm you or the device if used improperly.
    • Take the soldering iron after it has been heated up and place it where the ground (black) wire is connected to the logic board.
    • Let it heat up and remove some of the solder with the solder vacuum.
    • Do the same for the power (red) wire.
  7. PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement: adım 7, 1 resimden 1.
    • Now take the new rumble motor and place the power (red) wire on the right hole where the (+) sign is.
    • Take some solder and seal the hole so that the solder is completely covering the (+) hole.
    • Do the same for the ground wire.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Austin Miller
192 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 3-1, Harley Fall 2015 IUPUI, Team 3-1, Harley Fall 2015 üyesi
IUPUI-HARLEY-F15S3G1
4 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Where can I purchase just the rumble motors? I'd like to try adding rumble to a PDP Rock Candy controller, which is essentially the same controller as the AfterGlow but in a neon colored shell and no LED lighting. I don't know if they'll actually work but it would be a fun project.
Josh Koontz - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 28
Her zaman: 2,669
