Giriş
Caution: This guide includes using a soldering iron and can damage your controller or your hand if not used properly.
Neye ihtiyacın var
Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
Lift the Logic Board and remove the rumble motors from the base of the controller.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Where can I purchase just the rumble motors? I'd like to try adding rumble to a PDP Rock Candy controller, which is essentially the same controller as the AfterGlow but in a neon colored shell and no LED lighting. I don't know if they'll actually work but it would be a fun project.
