Ana içeriğe geç
PDP Rematch Advanced Back Buttons Replacement
Neye ihtiyacın var
  1. PDP Rematch Advanced Back Buttons Replacement, Joystick Cover: adım 1, 3 resimden 1. PDP Rematch Advanced Back Buttons Replacement, Joystick Cover: adım 1, 3 resimden 2. PDP Rematch Advanced Back Buttons Replacement, Joystick Cover: adım 1, 3 resimden 3.
    • Orient the controller so the back side is facing you.
    • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
    FixBot'a Sor
    Yorum Ekle
  2. PDP Rematch Advanced Back Buttons Replacement: adım 2, 3 resimden 1. PDP Rematch Advanced Back Buttons Replacement: adım 2, 3 resimden 2. PDP Rematch Advanced Back Buttons Replacement: adım 2, 3 resimden 3.
    • Pull apart the controller's front and back shells with moderate force.
    • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
    FixBot'a Sor
    Yorum Ekle
  3. PDP Rematch Advanced Back Buttons Replacement: adım 3, 2 resimden 1. PDP Rematch Advanced Back Buttons Replacement: adım 3, 2 resimden 2.
    • Twist the thumbstick to remove it from the motherboard. Repeat this step if both thumbsticks need to be replaced.
    FixBot'a Sor
    Yorum Ekle
  4. PDP Rematch Advanced Back Buttons Replacement, Back Shell: adım 4, 2 resimden 1. PDP Rematch Advanced Back Buttons Replacement, Back Shell: adım 4, 2 resimden 2.
    • Grab the motor and pull away from the back shell. Repeat for both motors.
    FixBot'a Sor
    Yorum Ekle
  5. PDP Rematch Advanced Back Buttons Replacement: adım 5, 2 resimden 1. PDP Rematch Advanced Back Buttons Replacement: adım 5, 2 resimden 2.
    • Use a Phillips #00 Screwdriver to remove the two 5mm screws from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  6. PDP Rematch Advanced Back Buttons Replacement: adım 6, 3 resimden 1. PDP Rematch Advanced Back Buttons Replacement: adım 6, 3 resimden 2. PDP Rematch Advanced Back Buttons Replacement: adım 6, 3 resimden 3.
    • Remove the motherboard from the back shell using moderate force.
    FixBot'a Sor
    Yorum Ekle
  7. PDP Rematch Advanced Back Buttons Replacement, Back Buttons: adım 7, 2 resimden 1. PDP Rematch Advanced Back Buttons Replacement, Back Buttons: adım 7, 2 resimden 2.
    • Use a Phillips #00 to remove the two 5mm screws from the back buttons.
    FixBot'a Sor
    Yorum Ekle
  8. PDP Rematch Advanced Back Buttons Replacement: adım 8, 3 resimden 1. PDP Rematch Advanced Back Buttons Replacement: adım 8, 3 resimden 2. PDP Rematch Advanced Back Buttons Replacement: adım 8, 3 resimden 3.
    • Lift the back button, and then pull it out through the back shell. Do this for both back buttons.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Collin Lawe
462 İtibar
3 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 36
Her zaman: 684
