Ana içeriğe geç
PDP Rematch Advanced Back Shell Replacement
Neye ihtiyacın var
  1. PDP Rematch Advanced Back Shell Replacement, Joystick Cover: adım 1, 3 resimden 1. PDP Rematch Advanced Back Shell Replacement, Joystick Cover: adım 1, 3 resimden 2. PDP Rematch Advanced Back Shell Replacement, Joystick Cover: adım 1, 3 resimden 3.
    • Orient the controller so the back side is facing you.
    • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
    FixBot'a Sor
  2. PDP Rematch Advanced Back Shell Replacement: adım 2, 3 resimden 1. PDP Rematch Advanced Back Shell Replacement: adım 2, 3 resimden 2. PDP Rematch Advanced Back Shell Replacement: adım 2, 3 resimden 3.
    • Pull apart the controller's front and back shells with moderate force.
    • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
    FixBot'a Sor
  3. PDP Rematch Advanced Back Shell Replacement: adım 3, 2 resimden 1. PDP Rematch Advanced Back Shell Replacement: adım 3, 2 resimden 2.
    • Twist the thumbstick to remove it from the motherboard. Repeat this step if both thumbsticks need to be replaced.
    FixBot'a Sor
  4. PDP Rematch Advanced Back Shell Replacement, Back Shell: adım 4, 2 resimden 1. PDP Rematch Advanced Back Shell Replacement, Back Shell: adım 4, 2 resimden 2.
    • Grab the motor and pull away from the back shell. Repeat for both motors.
    FixBot'a Sor
  5. PDP Rematch Advanced Back Shell Replacement: adım 5, 2 resimden 1. PDP Rematch Advanced Back Shell Replacement: adım 5, 2 resimden 2.
    • Use a Phillips #00 Screwdriver to remove the two 5mm screws from the motherboard.
    FixBot'a Sor
  6. PDP Rematch Advanced Back Shell Replacement: adım 6, 3 resimden 1. PDP Rematch Advanced Back Shell Replacement: adım 6, 3 resimden 2. PDP Rematch Advanced Back Shell Replacement: adım 6, 3 resimden 3.
    • Remove the motherboard from the back shell using moderate force.
    FixBot'a Sor
Sonuç
Angel Velasquez
369 İtibar
3 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 42
Her zaman: 486
