Ana içeriğe geç
PDP Rematch Advanced Front Housing Shell Replacement
Neye ihtiyacın var
  1. PDP Rematch Advanced Front Housing Shell Replacement, Front Housing Shell: adım 1, 3 resimden 1. PDP Rematch Advanced Front Housing Shell Replacement, Front Housing Shell: adım 1, 3 resimden 2. PDP Rematch Advanced Front Housing Shell Replacement, Front Housing Shell: adım 1, 3 resimden 3.
    • Orient the controller so the back side is facing you.
    • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
    FixBot'a Sor
    Yorum Ekle
  2. PDP Rematch Advanced Front Housing Shell Replacement: adım 2, 3 resimden 1. PDP Rematch Advanced Front Housing Shell Replacement: adım 2, 3 resimden 2. PDP Rematch Advanced Front Housing Shell Replacement: adım 2, 3 resimden 3.
    • Pull apart the controller's front and back shells with moderate force.
    • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
    FixBot'a Sor
    Yorum Ekle
  3. PDP Rematch Advanced Front Housing Shell Replacement: adım 3, 3 resimden 1. PDP Rematch Advanced Front Housing Shell Replacement: adım 3, 3 resimden 2. PDP Rematch Advanced Front Housing Shell Replacement: adım 3, 3 resimden 3.
    • Peel the rubber piece off the back of the face buttons.
    FixBot'a Sor
    Yorum Ekle
  4. PDP Rematch Advanced Front Housing Shell Replacement: adım 4, 3 resimden 1. PDP Rematch Advanced Front Housing Shell Replacement: adım 4, 3 resimden 2. PDP Rematch Advanced Front Housing Shell Replacement: adım 4, 3 resimden 3.
    • Push all the face buttons out from the front of the shell.
    FixBot'a Sor
    Yorum Ekle
  5. PDP Rematch Advanced Front Housing Shell Replacement: adım 5, 3 resimden 1. PDP Rematch Advanced Front Housing Shell Replacement: adım 5, 3 resimden 2. PDP Rematch Advanced Front Housing Shell Replacement: adım 5, 3 resimden 3.
    • Put two fingers behind the bumpers and push upwards to remove them.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Collin Lawe
462 İtibar
3 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 11
Son 30 gün: 36
Her zaman: 472
