Ana içeriğe geç
PDP Rematch Advanced Trigger Springs Replacement
Neye ihtiyacın var
  1. PDP Rematch Advanced Trigger Springs Replacement, Trigger Springs: adım 1, 2 resimden 1. PDP Rematch Advanced Trigger Springs Replacement, Trigger Springs: adım 1, 2 resimden 2.
    • Orient the controller so the back side is facing you.
    • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
    FixBot'a Sor
    Yorum Ekle
  2. PDP Rematch Advanced Trigger Springs Replacement: adım 2, 3 resimden 1. PDP Rematch Advanced Trigger Springs Replacement: adım 2, 3 resimden 2. PDP Rematch Advanced Trigger Springs Replacement: adım 2, 3 resimden 3.
    • Pull apart the controller's front and back shells with moderate force.
    • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
    FixBot'a Sor
    Yorum Ekle
  3. PDP Rematch Advanced Trigger Springs Replacement: adım 3, 2 resimden 1. PDP Rematch Advanced Trigger Springs Replacement: adım 3, 2 resimden 2.
    • Twist the thumbstick to remove it from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  4. PDP Rematch Advanced Trigger Springs Replacement: adım 4, 3 resimden 1. PDP Rematch Advanced Trigger Springs Replacement: adım 4, 3 resimden 2. PDP Rematch Advanced Trigger Springs Replacement: adım 4, 3 resimden 3.
    • Use a Phillips #000 screwdriver to remove the two 5 mm screws that secure the motherboard.
    • Remove the motherboard from the back shell using moderate force.
    FixBot'a Sor
    Yorum Ekle
  5. PDP Rematch Advanced Trigger Springs Replacement: adım 5, 3 resimden 1. PDP Rematch Advanced Trigger Springs Replacement: adım 5, 3 resimden 2. PDP Rematch Advanced Trigger Springs Replacement: adım 5, 3 resimden 3.
    • Punch out the metal pin holding in the trigger and the trigger spring. Repeat for both triggers.
    • Remove the trigger and the trigger springs.
    • Using a punch or a small tool allows pin removal to be easier.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jacob Thomas Wolgamott
121 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 60
Her zaman: 626
