Ana içeriğe geç
PDP Rematch Advanced Triggers Replacement
Neye ihtiyacın var
  1. PDP Rematch Advanced Triggers Replacement, Triggers: adım 1, 2 resimden 1. PDP Rematch Advanced Triggers Replacement, Triggers: adım 1, 2 resimden 2.
    • Orient the controller so the back side is facing you.
    • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
  2. PDP Rematch Advanced Triggers Replacement: adım 2, 2 resimden 1. PDP Rematch Advanced Triggers Replacement: adım 2, 2 resimden 2.
    • Pull apart the controller's front and back shells with moderate force.
    • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
  3. PDP Rematch Advanced Triggers Replacement: adım 3, 2 resimden 1. PDP Rematch Advanced Triggers Replacement: adım 3, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the two 5 mm screws that secure the motherboard.
  4. PDP Rematch Advanced Triggers Replacement: adım 4, 1 resimden 1.
    • Remove the motherboard from the back shell using moderate force.
  5. PDP Rematch Advanced Triggers Replacement: adım 5, 2 resimden 1. PDP Rematch Advanced Triggers Replacement: adım 5, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the two trigger springs from the motherboard.
  6. PDP Rematch Advanced Triggers Replacement: adım 6, 2 resimden 1. PDP Rematch Advanced Triggers Replacement: adım 6, 2 resimden 2.
    • Use a hair dryer to remove the trigger from the motherboard.
Sonuç
Kevin Crawford
133 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 42
Her zaman: 339
