Ana içeriğe geç
PDP Rematch Cable Replacement
Neye ihtiyacın var
  1. PDP Rematch Cable Replacement, Faceplate: adım 1, 2 resimden 1. PDP Rematch Cable Replacement, Faceplate: adım 1, 2 resimden 2.
    • Grip one side of the controller firmly.
    • Insert an opening pick into the crease between the faceplate and the body of the controller.
    • Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
    • Carefully move the picks along the controller's crease line until you hear a popping sound.
    • Gently lift off the faceplate by hand.
    FixBot'a Sor
    Yorum Ekle
  2. PDP Rematch Cable Replacement: adım 2, 2 resimden 1. PDP Rematch Cable Replacement: adım 2, 2 resimden 2.
    • Remove the 8 mm screws from the hard cover using a JIS #00 screwdriver.
    • Since the screws have been removed, avoid shaking or moving your controller too much to prevent other buttons from falling out.
    FixBot'a Sor
    Yorum Ekle
  3. PDP Rematch Cable Replacement: adım 3, 2 resimden 1. PDP Rematch Cable Replacement: adım 3, 2 resimden 2.
    • Gently lift off the hard cover with your hand; it should not need much force.
    FixBot'a Sor
    Yorum Ekle
  4. PDP Rematch Cable Replacement, Cable: adım 4, 1 resimden 1.
    • Remove the two screws on the motherboard with a JIS #000 screwdriver.
    • Gently flip the motherboard up to see the other side.
    FixBot'a Sor
    Yorum Ekle
  5. PDP Rematch Cable Replacement: adım 5, 1 resimden 1.
    • Remove the cable from its plug on the motherboard.
    • This should give you room to carefully detach the Male Pitch Terminal Pin Header from the Female Terminal Pin.
    FixBot'a Sor
    Yorum Ekle
  6. PDP Rematch Cable Replacement: adım 6, 1 resimden 1.
    • Take the new cable and thread it through the slot. The terminal block should fit loosely into the slot.
    • Then, insert the Male Pitch Terminal Pin into the Female Terminal Pin.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Sydney Foster
97 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
Where do I buy the replacement cord from?
Keithy Bruce - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 47
Her zaman: 662
