Ana içeriğe geç
PDP Rematch Faceplate Replacement
Neye ihtiyacın var
  1. PDP Rematch Faceplate Replacement, Faceplate: adım 1, 2 resimden 1. PDP Rematch Faceplate Replacement, Faceplate: adım 1, 2 resimden 2.
    • Grip one side of the controller firmly.
    • Insert an opening pick into the crease between the faceplate and the body of the controller.
    • Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
    • Carefully move the picks along the controller's crease line until you hear a popping sound.
    • Gently lift off the faceplate by hand.
    FixBot'a Sor
    Yorum Ekle
  2. PDP Rematch Faceplate Replacement: adım 2, 2 resimden 1. PDP Rematch Faceplate Replacement: adım 2, 2 resimden 2.
    • Remove the 8 mm screws from the hard cover using a JIS #00 screwdriver.
    • Since the screws have been removed, avoid shaking or moving your controller too much to prevent other buttons from falling out.
    FixBot'a Sor
    Yorum Ekle
  3. PDP Rematch Faceplate Replacement: adım 3, 2 resimden 1. PDP Rematch Faceplate Replacement: adım 3, 2 resimden 2.
    • Gently lift off the hard cover with your hand; it should not need much force.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Amina Begum
282 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 61
Her zaman: 807
