Ana içeriğe geç
PDP Victrix Gambit Prime Joystick Cover Replacement
Neye ihtiyacın var
  1. PDP Victrix Gambit Prime Joystick Cover Replacement, Joystick Cover: adım 1, 1 resimden 1.
    • Insert an opening tool in the gap between the rear and front case.
    • Pry around the perimeter until the front case releases.
    • Remove the front case.
    • If your device has a circular Directional Pad, remove it first to access the faceplate.
  2. PDP Victrix Gambit Prime Joystick Cover Replacement: adım 2, 1 resimden 1.
    • Firmly grasp the joystick cover and pull it straight up and off of the controller.
  3. PDP Victrix Gambit Prime Joystick Cover Replacement: adım 3, 1 resimden 1.
    • Align the new joystick with the controller's socket; press down until it clicks into place.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tessa Baldwin
605 İtibar
5 adet Kılavuz yazıldı
1Rehber Yorum
Helpful and clear instructions given by the Author. Although an opening tool is definitely overkill for removing the faceplate as it's held on by a few magnets and requires little effort. If the faceplate doesn't come off easily it's probably because you need to remove the circular D-Pad (which the Author mentions in Step 1 - "i")
Nate Allen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 29
Her zaman: 121
