Ana içeriğe geç
PDP Victrix Gambit Prime Outer Case Replacement
Neye ihtiyacın var
  1. PDP Victrix Gambit Prime Outer Case Replacement, Outer Casing: adım 1, 1 resimden 1.
    • Insert an opening tool in the gap between the rear and front case.
    • Pry around the perimeter until the front case releases.
    • Remove the front case.
  2. PDP Victrix Gambit Prime Outer Case Replacement: adım 2, 1 resimden 1.
    • Remove all seven 9 mm Phillips #000 screws securing the midframe.
    • Remove the midframe.
  3. PDP Victrix Gambit Prime Outer Case Replacement: adım 3, 2 resimden 1. PDP Victrix Gambit Prime Outer Case Replacement: adım 3, 2 resimden 2.
    • Optional: With a pair of tweezers, carefully wipe down the device.
    • It is recommended to use electrical disinfectant wipes or a microfiber towel to clean any excess debris.
Sonuç
After you have thoroughly cleaned the device, follow these steps in reverse order to reassemble the device.
Tessa Baldwin
605 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 69
