Ana içeriğe geç
PDP Victrix Pro BFG Battery and Trigger Replacement
Neye ihtiyacın var
  1. PDP Victrix Pro BFG Battery and Trigger Replacement, Battery and Trigger: adım 1, 1 resimden 1.
    • Use the purple Module Swap Tool that comes with the device to remove the 4 hex screws.
    • Remove the joystick/button modules from the controller.
    FixBot'a Sor
    Yorum Ekle
  2. PDP Victrix Pro BFG Battery and Trigger Replacement: adım 2, 1 resimden 1.
    • Remove the screws from each of the module compartments using a PH0 or J1 bit.
    FixBot'a Sor
    Yorum Ekle
  3. PDP Victrix Pro BFG Battery and Trigger Replacement: adım 3, 2 resimden 1. PDP Victrix Pro BFG Battery and Trigger Replacement: adım 3, 2 resimden 2.
    • Using the iFixit opening tool, gently pry open the two side grips.
    • Using a PH0 or J1 screwdriver bit with a 4mm diameter or less, remove the screws located in the bottom outside corners.
    FixBot'a Sor
    Yorum Ekle
  4. PDP Victrix Pro BFG Battery and Trigger Replacement: adım 4, 1 resimden 1.
    • Flip the controller to the other side so the label on the bottom is facing upwards.
    • On the label, there is a circular icon; this shows the location of a single screw.
    • Using the same PH0 or J1 screwdriver bit from the previous steps, remove the screw.
    FixBot'a Sor
    Yorum Ekle
  5. PDP Victrix Pro BFG Battery and Trigger Replacement: adım 5, 1 resimden 1.
    • Flip the controller so the charging port of the controller is facing you.
    • Using a spudger, carefully pry open the front component.
    FixBot'a Sor
    Yorum Ekle
  6. PDP Victrix Pro BFG Battery and Trigger Replacement: adım 6, 1 resimden 1.
    • Flip the controller so it is upside-down, but the charging port is still facing you.
    • In the center of the now exposed part, there will be a hidden silver screw.
    • Use the flexible piece attached to the screwdriver to remove this screw.
    • Now that everything is loosened, gently pry open the controller along the grooves.
    FixBot'a Sor
    Yorum Ekle
  7. PDP Victrix Pro BFG Battery and Trigger Replacement: adım 7, 1 resimden 1.
    • Using the screwdriver tool with a smaller head, remove the three screws from each trigger.
    • Remove the triggers.
    FixBot'a Sor
    Yorum Ekle
  8. PDP Victrix Pro BFG Battery and Trigger Replacement: adım 8, 1 resimden 1.
    • Using the screwdriver, remove the two screws in the bottom two corners.
    • Using the halberd spudger, carefully pry the circuit board open.
    FixBot'a Sor
    Yorum Ekle
  9. PDP Victrix Pro BFG Battery and Trigger Replacement: adım 9, 1 resimden 1.
    • To remove the batteries, use a pair of tweezers to carefully unplug the batteries from the circuit board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
ryanmorabito
260 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-1, Santin Spring 2024 UMass Dartmouth, Team 1-1, Santin Spring 2024 üyesi
UMASSD-SANTIN-S24S1G1
3 Üyeler
4 adet Kılavuz yazıldı
5Kılavuz Yorumları
Only guide I could find to get this controller apart for my son. Now have to find someone to resolder the USB c port.
Matthew Lash - Yanıt Paylaş
R2 and L2 no response, the board location for button?
Terry - Yanıt Paylaş
if my remote doesn’t turn on or charge should I change the battery or just throw it away?
Nerdy mom - Yanıt Paylaş
How much and how can I buy the battery's?
Dino - Yanıt Paylaş
Really sucks that the L2 and R2 modules are all one big thing and not easily repairable. My R2 had a crack near the two screws and I went to Turtle Beach trying to get a replacement. They don't offer parts and I had to resort to superglue. I hope it holds up, but repairability for this controller is pretty low without access to the proprietary parts.
Michael Monn - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 65
Son 30 gün: 398
Her zaman: 7,247
