Ana içeriğe geç
PDP Victrix Pro BFG Battery and Trigger Replacement
Neye ihtiyacın var
  1. PDP Victrix Pro BFG Battery and Trigger Replacement, Battery and Trigger: adım 1, 1 resimden 1.
    • Use the purple Module Swap Tool that comes with the device to remove the 4 hex screws.
    • Remove the joystick/button modules from the controller.
  2. PDP Victrix Pro BFG Battery and Trigger Replacement: adım 2, 1 resimden 1.
    • Remove the two screws from the module compartments.
  3. PDP Victrix Pro BFG Battery and Trigger Replacement: adım 3, 2 resimden 1. PDP Victrix Pro BFG Battery and Trigger Replacement: adım 3, 2 resimden 2.
    • Using the iFixit opening tool, gently pry open the two side grips.
    • Using the screwdriver tool with a head of around 2 mm, remove the screws located in the bottom outside corners.
  4. PDP Victrix Pro BFG Battery and Trigger Replacement: adım 4, 1 resimden 1.
    • Flip the controller to the other side so the label on the bottom is facing upwards.
    • On the label, there is a circular icon; this shows the location of a single screw.
    • Using the same screwdriver head setting from the previous step, remove the screw.
  5. PDP Victrix Pro BFG Battery and Trigger Replacement: adım 5, 1 resimden 1.
    • Flip the controller so the charging port of the controller is facing you.
    • Using a spudger, carefully pry open the front component.
  6. PDP Victrix Pro BFG Battery and Trigger Replacement: adım 6, 1 resimden 1.
    • Flip the controller so it is upside-down, but the charging port is still facing you.
    • In the center of the now exposed part, there will be a hidden silver screw.
    • Use the flexible piece attached to the screwdriver to remove this screw.
    • Now that everything is loosened, gently pry open the controller along the grooves.
  7. PDP Victrix Pro BFG Battery and Trigger Replacement: adım 7, 1 resimden 1.
    • Using the screwdriver tool with a smaller head, remove the three screws from each trigger.
    • Remove the triggers.
  8. PDP Victrix Pro BFG Battery and Trigger Replacement: adım 8, 1 resimden 1.
    • Using the screwdriver, remove the two screws in the bottom two corners.
    • Using the halberd spudger, carefully pry the circuit board open.
  9. PDP Victrix Pro BFG Battery and Trigger Replacement: adım 9, 1 resimden 1.
    • To remove the batteries, use a pair of tweezers to carefully unplug the batteries from the circuit board.
Sonuç
ryanmorabito
169 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-1, Santin Spring 2024 UMass Dartmouth, Team 1-1, Santin Spring 2024 üyesi
UMASSD-SANTIN-S24S1G1
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 31
Son 30 gün: 137
Her zaman: 178
