Ana içeriğe geç
PDP Victrix Pro BFG Joysticks Replacement
Neye ihtiyacın var
  1. PDP Victrix Pro BFG Joysticks Replacement, Joysticks: adım 1, 1 resimden 1.
    • Use the purple Module Swap Tool that comes with the device to remove the 4 hex screws.
    • Remove the joystick/button modules from the controller.
    FixBot'a Sor
    Yorum Ekle
  2. PDP Victrix Pro BFG Joysticks Replacement: adım 2, 2 resimden 1. PDP Victrix Pro BFG Joysticks Replacement: adım 2, 2 resimden 2.
    • Turn over the joystick/button module
    • Remove four 1 mm screws using a Phillips #0 screwdriver.
    • Take the plate off with the buttons and set aside.
    • You can use this step to replace the buttons if one is damaged or if you would like to customize them.
    FixBot'a Sor
    Yorum Ekle
  3. PDP Victrix Pro BFG Joysticks Replacement: adım 3, 1 resimden 1.
    • Using a soldering iron, desolder the the bottom part of the joystick.
    • The soldering iron is very hot; be careful to not make contact with skin.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jacob Gorman
197 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-1, Santin Spring 2024 UMass Dartmouth, Team 1-1, Santin Spring 2024 üyesi
UMASSD-SANTIN-S24S1G1
3 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 29
Son 30 gün: 143
Her zaman: 2,491
