Ana içeriğe geç
PDP Victrix Pro BFG Joysticks Replacement
Neye ihtiyacın var
  1. PDP Victrix Pro BFG Joysticks Replacement, Joysticks: adım 1, 1 resimden 1.
    • Use the purple Module Swap Tool that comes with the device to remove the 4 hex screws.
    • Remove the joystick/button modules from the controller.
  2. PDP Victrix Pro BFG Joysticks Replacement: adım 2, 2 resimden 1. PDP Victrix Pro BFG Joysticks Replacement: adım 2, 2 resimden 2.
    • Turn over the joystick/button module
    • Remove four 1 mm screws using a Phillips #0 screwdriver.
    • Take the plate off with the buttons and set aside.
    • You can use this step to replace the buttons if one is damaged or if you would like to customize them.
  3. PDP Victrix Pro BFG Joysticks Replacement: adım 3, 1 resimden 1.
    • Using a soldering iron, desolder the the bottom part of the joystick.
    • The soldering iron is very hot; be careful to not make contact with skin.
Sonuç
Jacob Gorman
197 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-1, Santin Spring 2024 UMass Dartmouth, Team 1-1, Santin Spring 2024 üyesi
UMASSD-SANTIN-S24S1G1
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 21
Son 30 gün: 101
Her zaman: 158
