Ana içeriğe geç
PENTAX OPTIO 330 Internal Battery replacement
Neye ihtiyacın var
  1. PENTAX OPTIO 330 Internal Battery replacement, Remove rear bloc: adım 1, 1 resimden 1.
    • remove the two 2.5mm screw of the left side
  2. PENTAX OPTIO 330 Internal Battery replacement, Remove rear bloc: adım 2, 1 resimden 1.
    • Remove two 4mm screw of the right side
  3. PENTAX OPTIO 330 Internal Battery replacement, Remove rear bloc: adım 3, 1 resimden 1.
    • remove 2mm screw
    • remove 3mm screw
    • remove the three 3.5mm screw
  4. PENTAX OPTIO 330 Internal Battery replacement, Remove rear cover: adım 4, 3 resimden 1. PENTAX OPTIO 330 Internal Battery replacement, Remove rear cover: adım 4, 3 resimden 2. PENTAX OPTIO 330 Internal Battery replacement, Remove rear cover: adım 4, 3 resimden 3.
    • Open the memory protection
    • Remove gently the rear cover
    • When re-assembly take care to the thin tabs
  5. PENTAX OPTIO 330 Internal Battery replacement, Remove rear cover: adım 5, 2 resimden 1. PENTAX OPTIO 330 Internal Battery replacement, Remove rear cover: adım 5, 2 resimden 2.
    • this part can fall down. So rome it before next step.
  6. PENTAX OPTIO 330 Internal Battery replacement, Front cover remove: adım 6, 3 resimden 1. PENTAX OPTIO 330 Internal Battery replacement, Front cover remove: adım 6, 3 resimden 2. PENTAX OPTIO 330 Internal Battery replacement, Front cover remove: adım 6, 3 resimden 3.
    • Insérez ici votre traduction
  7. PENTAX OPTIO 330 Internal Battery replacement: adım 7, 1 resimden 1.
    • Remove four screw
    • unplug the two Flex
  8. PENTAX OPTIO 330 Internal Battery replacement, Battery replacement: adım 8, 2 resimden 1. PENTAX OPTIO 330 Internal Battery replacement, Battery replacement: adım 8, 2 resimden 2.
    • This connector is directly to the board
    • This Flex connector need to be unplug
    • The 321 battery is there
    • You can add some thermal glue to fix the battery
    • I did it with a small piece of scotch
Sonuç
To re-assembly your device follow the step backward
Bu çevirmenlere özel teşekkürler:
fr en
100%
Bertrand PIGEARD dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Bertrand PIGEARD
235 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 265
