Ana içeriğe geç
PNY Geforce GT 710 Fan/heatsink Replacement
Neye ihtiyacın var
  1. PNY Geforce GT 710 Fan/heatsink Replacement, Remove the four screws on the back: adım 1, 1 resimden 1.
    • The four screws on the back should be removed in a cross pattern and use a Phillips screwdriver
  2. PNY Geforce GT 710 Fan/heatsink Replacement, Remove the fan connector: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • If you have tweezers use them and make sure to be careful and to pull up on the connector and not the wires or the base as both risk damaging the device.
Sonuç
To reassemble your device, follow these instructions in reverse order and make sure to use the cross pattern when reserving the back screws holding the fan in place.
Bir başkası bu kılavuzu tamamladı.
Zachary Stensrud
144 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 32
Her zaman: 400
