Ana içeriğe geç
PRS Guitar Pickups Replacement
Neye ihtiyacın var
  1. PRS Guitar Pickups Replacement, Pickups: adım 1, 2 resimden 1. PRS Guitar Pickups Replacement, Pickups: adım 1, 2 resimden 2.
    • Loosen all of the strings until they can be pulled out of the tuners.
    • Pull the strings through the bridge and out of the back side of the guitar.
  2. PRS Guitar Pickups Replacement: adım 2, 2 resimden 1. PRS Guitar Pickups Replacement: adım 2, 2 resimden 2.
    • Using a Phillips head screwdriver, unscrew the back plate, revealing the pickup wiring.
  3. PRS Guitar Pickups Replacement: adım 3, 1 resimden 1.
    • Take note of the wiring before desoldering the wires.
    • Begin desoldering the pickup wires.
    • Take care when soldering, as the tip is very hot.
  4. PRS Guitar Pickups Replacement: adım 4, 2 resimden 1. PRS Guitar Pickups Replacement: adım 4, 2 resimden 2.
    • Turn the guitar face up and unscrew both of the pickups.
    • Take the pickups out of the guitar.
  5. PRS Guitar Pickups Replacement: adım 5, 2 resimden 1. PRS Guitar Pickups Replacement: adım 5, 2 resimden 2.
    • Refer to the wiring arrangements you took note of as well as the wiring manual that came with your new pickups.
    • Run the new pickups back through the guitar with the wires guided through the back plate.
    • Carefully begin soldering the new pickup wires back together.
  6. PRS Guitar Pickups Replacement: adım 6, 1 resimden 1.
    • This is a good opportunity to clean the guitar.
    • Begin restringing the guitar with new strings of your preference.
    • Using a string/wire cutter and cut excess strings from tuners.
Bitiş Çizgisi
Nathan Kevil
141 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 23
Her zaman: 750
