Ana içeriğe geç
PS Vita Slim Battery Replacement
Neye ihtiyacın var
  1. PS Vita Slim Battery  Replacement, Back Panel: adım 1, 1 resimden 1.
    • Please make sure the system is completely powered off and all SD storage cards are removed before starting the removal process
    • All 6.35mm screws were removed using a J00 bit from the iFixit pro toolkit.
    • There are four screws on the back of the device, remove them as shown.
    FixBot'a Sor
    Yorum Ekle
  2. PS Vita Slim Battery  Replacement: adım 2, 2 resimden 1. PS Vita Slim Battery  Replacement: adım 2, 2 resimden 2.
    • There are two screws on the bottom, near the charging port, remove them using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
    • Finally, remove the top screw under the dust cover using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
    FixBot'a Sor
    Yorum Ekle
  3. PS Vita Slim Battery  Replacement: adım 3, 3 resimden 1. PS Vita Slim Battery  Replacement: adım 3, 3 resimden 2. PS Vita Slim Battery  Replacement: adım 3, 3 resimden 3.
    • The next step will require the opening tool.
    • Please carefully separate the back from the front completely. You will need to disconnect the small ribbon cable on the inside before completely removing the back. Otherwise you may end up hurting the ribbons on the inside.
    • While separating the back, carefully pry all the way around the back. You will hear popping noises while going around and this is a good sign.
    • Upon removing the back panel you will need to slowly and carefully remove the ribbons connecting the hardware to access the needed parts to be repaired.
    FixBot'a Sor
    Yorum Ekle
  4. PS Vita Slim Battery  Replacement: adım 4, 1 resimden 1.
    • Once the ribbons have been removed, then the back is fully removed and you can access the hardware within.
    FixBot'a Sor
    Yorum Ekle
  5. PS Vita Slim Battery  Replacement, Battery: adım 5, 3 resimden 1. PS Vita Slim Battery  Replacement, Battery: adım 5, 3 resimden 2. PS Vita Slim Battery  Replacement, Battery: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Spudger
    $3.99
    • The battery should be very visible at this point in the guide.
    • Using the spudger, carefully pry the battery connector upwards out of the socket. Do not fully remove the battery yet.
    • Now using the tweezers, carefully remove the ribbon connecting the battery from the hardware.
    • The battery isn't held in by anything, so it can fall out of the case if turned upside down.
    FixBot'a Sor
    Yorum Ekle
  6. PS Vita Slim Battery  Replacement: adım 6, 1 resimden 1.
    • Now the battery is removable and the process should be complete. You should be free to do what is needed.
    FixBot'a Sor
    Yorum Ekle
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
4Kılavuz Yorumları
Whilst tearing down my PCH-2016 model PS Vita Slim I have noticed that there is also a screw in the cartridge area that needs to be removed to remove the back panel.
Jack Wallis - Yanıt Paylaş
The touchpad cable isn't able to be re-attached if you do this so your vita just ends up becoming permanently crippled. DO NOT FOLLOW THIS GUIDE.
polocatfan - Yanıt Paylaş
@polocatfan yes it can? just needs some good technique
Darryl C - Yanıt Paylaş
@squirrelmuncher can 100% confirm it's impossible. I tried for hours.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 30
Son 7 gün: 236
Son 30 gün: 1,173
Her zaman: 48,144
