Ana içeriğe geç
PSP 1000 Front Casing Replacement
Neye ihtiyacın var
    1. PSP 1000 Front Casing Replacement, Battery: adım 1, 1 resimden 1.
      • Turn the PSP over so its back is facing you.
      FixBot'a Sor
      Yorum Ekle
    2. PSP 1000 Front Casing Replacement: adım 2, 2 resimden 1. PSP 1000 Front Casing Replacement: adım 2, 2 resimden 2.
      • Locate the battery casing button on the rear-left side of the PSP.
      • Press down the button and remove the battery cover.
      FixBot'a Sor
      Yorum Ekle
    3. PSP 1000 Front Casing Replacement: adım 3, 2 resimden 1. PSP 1000 Front Casing Replacement: adım 3, 2 resimden 2.
      • Using your finger, remove the battery upwards from the system as shown.
      FixBot'a Sor
      Yorum Ekle
    1. PSP 1000 Front Casing Replacement, Front Casing: adım 4, 1 resimden 1.
      • Remove the four screws shown with a Phillips #00 screwdriver.
      • You will have to peel back the warranty sticker to access the lower screws.
      FixBot'a Sor
      Yorum Ekle
    2. PSP 1000 Front Casing Replacement: adım 5, 2 resimden 1. PSP 1000 Front Casing Replacement: adım 5, 2 resimden 2.
      • Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
      • Remove the two screws from the back righthand side within the holes.
      FixBot'a Sor
      Yorum Ekle
    3. PSP 1000 Front Casing Replacement: adım 6, 2 resimden 1. PSP 1000 Front Casing Replacement: adım 6, 2 resimden 2.
      • Gently separate the outer plastic casing from the rest of the system as shown.
      FixBot'a Sor
      Yorum Ekle
Sonuç
36 farklı kişi bu kılavuzu tamamladı.
Henry Lee
908 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-6, Forte Winter 2010 Cal Poly, Team 5-6, Forte Winter 2010 üyesi
CPSU-FORTE-W10S5G6
5 Üyeler
40 adet Kılavuz yazıldı
3Kılavuz Yorumları
Thank you! Awesome help!
Jay Vee - Yanıt Paylaş
My psp is updating then psp is fallen down and battery comeout so please help me please thank you
Bye
National Nazeer - Yanıt Paylaş
i also made a video on this for anyone who needs to do it that way.
https://www.youtube.com/watch?v=EIAaJyIx...
DAS Repair - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 135
Son 30 gün: 621
Her zaman: 52,675
