Ana içeriğe geç
PSP 1000 LCD Screen Replacement
Neye ihtiyacın var
  1. PSP 1000 LCD Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the PSP over so its back is facing you.
  2. PSP 1000 LCD Screen Replacement: adım 2, 2 resimden 1. PSP 1000 LCD Screen Replacement: adım 2, 2 resimden 2.
    • Locate the battery casing button on the rear-left side of the PSP.
    • Press down the button and remove the battery cover.
  3. PSP 1000 LCD Screen Replacement: adım 3, 2 resimden 1. PSP 1000 LCD Screen Replacement: adım 3, 2 resimden 2.
    • Using your finger, remove the battery upwards from the system as shown.
  4. PSP 1000 LCD Screen Replacement, Front Casing: adım 4, 1 resimden 1.
    • Remove the four screws shown with a Phillips #00 screwdriver.
    • You will have to peel back the warranty sticker to access the lower screws.
  5. PSP 1000 LCD Screen Replacement: adım 5, 2 resimden 1. PSP 1000 LCD Screen Replacement: adım 5, 2 resimden 2.
    • Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
    • Remove the two screws from the back righthand side within the holes.
  6. PSP 1000 LCD Screen Replacement: adım 6, 2 resimden 1. PSP 1000 LCD Screen Replacement: adım 6, 2 resimden 2.
    • Gently separate the outer plastic casing from the rest of the system as shown.
  7. PSP 1000 LCD Screen Replacement, LCD Screen: adım 7, 1 resimden 1.
    • The Button Board, at the base of the LCD Screen, is held by two clips.
    • Pry these clips over the nubs using a PSP opening tool. This will release the clips.
    • The Button Board is still attatched to the PSP by a ribbon cable!
  8. PSP 1000 LCD Screen Replacement: adım 8, 3 resimden 1. PSP 1000 LCD Screen Replacement: adım 8, 3 resimden 2. PSP 1000 LCD Screen Replacement: adım 8, 3 resimden 3.
    • The Button Board Ribbon Cable is held down with a latch. Lift the latch open, away from the ribbon cable.
    • Pull the cable away from the latch.
  9. PSP 1000 LCD Screen Replacement: adım 9, 2 resimden 1. PSP 1000 LCD Screen Replacement: adım 9, 2 resimden 2.
    • The LCD Screen is held by the LCD Frame with similar clips. Slide a thin tool between the clip and the screen and gently pry them apart while beginning to lift the screen.
  10. PSP 1000 LCD Screen Replacement: adım 10, 1 resimden 1.
    • The LCD screen is still attached with ribbon cables. Gently lift up the LCD screen so you do not break them.
  11. PSP 1000 LCD Screen Replacement: adım 11, 3 resimden 1. PSP 1000 LCD Screen Replacement: adım 11, 3 resimden 2. PSP 1000 LCD Screen Replacement: adım 11, 3 resimden 3.
    • The thin Ribbon Cable opens from the opposite side in which the Ribbon Cable enters. Open up the latch towards the Ribbon Cable. The latch will pull up and release the ribbon cable. Put your tool behind the black part, then pry up the black piece of plastic.
    • The wide Ribbon Cable opens from the same side in which the Ribbon Cable attatches, and opens away from the cable.
    • Both of these latches are the black pieces.
    • Gently pull the ribbon cables away from the latches. The LCD screen can now be removed.
    • When reassembling - be careful which way you push the latches. The small one is very easy to break.
Bitiş Çizgisi
81 farklı kişi bu kılavuzu tamamladı.
Henry Lee
866 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-6, Forte Winter 2010 Cal Poly, Team 5-6, Forte Winter 2010 üyesi
CPSU-FORTE-W10S5G6
5 Üyeler
34 adet Kılavuz yazıldı
8Kılavuz Yorumları
I broke one of the laches....helppp!!!!
janet - Yanıt Paylaş
This is not easy...I tore up the outer casing trying to do this. I better see money in the mail for this
Justin Autrey - Yanıt Paylaş
My Sony PSP has just stop coming on
lil bao - Yanıt Paylaş
People!! If you weren't gifted in screws and bolts, then bring your console to a repair shop. Seriously blaming this for your Dick Fingers?
janisfranckevics - Yanıt Paylaş
dick fingers!!
jonathon allen - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 42
Son 7 gün: 244
Son 30 gün: 1,071
Her zaman: 98,120
