Ana içeriğe geç
PSP 1000 LCD Screen Replacement
Neye ihtiyacın var
  1. PSP 1000 LCD Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the PSP over so its back is facing you.
  2. PSP 1000 LCD Screen Replacement: adım 2, 2 resimden 1. PSP 1000 LCD Screen Replacement: adım 2, 2 resimden 2.
    • Locate the battery casing button on the rear-left side of the PSP.
    • Press down the button and remove the battery cover.
    You are dumbbb... BRO YOUR DUMB BC U DIDNT HAVE TO USE A TOOL TO OPEN THE DOOR. USE YOUR FINGER""
    Paulo Moments - Yanıt
    The battery door can be damaged dont use a tool
    That also happend to me it got destroyed by screwdriver
  3. PSP 1000 LCD Screen Replacement: adım 3, 2 resimden 1. PSP 1000 LCD Screen Replacement: adım 3, 2 resimden 2.
    • Using your finger, remove the battery upwards from the system as shown.
    The use of the opening tool is completely unnecessary. There is a finger actuated opening latch button that says “PUSH” on it. Simply press down with your thumb then slide your thumb down and away, dragining the battery door with it. It will then come off. Assuming the system still has its original plastics, they may have become brittle enough that the opening tool could damage the release button or the plastic cover.
    Franklin Allen - Yanıt
  4. PSP 1000 LCD Screen Replacement, Front Casing: adım 4, 2 resimden 1. PSP 1000 LCD Screen Replacement, Front Casing: adım 4, 2 resimden 2.
    • Remove the four screws shown with a Phillips #00 screwdriver.
    • You will have to peel back the guarantee sticker to access the screw on the lower left.
    Much luck to you if you have a tiny, metal screwdriver like I did, the screws might be stuck in there and may require some force.
    Squib - Yanıt
    you need to peel back the warranty sticker in order to access both the lower left and lower left screws
    Frederick zzstu Geib - Yanıt
    This is a bit misleading, you should only remove the two black screws in the battery compartment. The silver ones can stay.
    Damian Cartwright - Yanıt
    The two left hand screws won’t come out of mine
    XULF - Yanıt
    iFixit screwdriver bits aren't thin enough to reach the two screws on the right near the memory stick slot.
    Fliggle_Slaps - Yanıt
    Can't edit previous comment so here's a new one:
    Standard or older iFixit screwdriver bits aren't thin enough to reach the two screws on the right near the memory stick slot. You'll need precision bits that have longer tips to reach these deep screws.
  5. PSP 1000 LCD Screen Replacement: adım 5, 1 resimden 1.
    • Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
    • Remove screws from back righthand side within the holes.
  6. PSP 1000 LCD Screen Replacement: adım 6, 2 resimden 1. PSP 1000 LCD Screen Replacement: adım 6, 2 resimden 2.
    • Gently separate the outer plastic casing from the rest of the system as shown.
  7. PSP 1000 LCD Screen Replacement, LCD Screen: adım 7, 1 resimden 1.
    • The Button Board, at the base of the LCD Screen, is held by two clips.
    • Pry these clips over the nubs using a PSP opening tool. This will release the clips.
    • The Button Board is still attatched to the PSP by a ribbon cable!
  8. PSP 1000 LCD Screen Replacement: adım 8, 3 resimden 1. PSP 1000 LCD Screen Replacement: adım 8, 3 resimden 2. PSP 1000 LCD Screen Replacement: adım 8, 3 resimden 3.
    • The Button Board Ribbon Cable is held down with a latch. Lift the latch open, away from the ribbon cable.
    • Pull the cable away from the latch.
  9. PSP 1000 LCD Screen Replacement: adım 9, 2 resimden 1. PSP 1000 LCD Screen Replacement: adım 9, 2 resimden 2.
    • The LCD Screen is held by the LCD Frame with similar clips. Slide a thin tool between the clip and the screen and gently pry them apart while beginning to lift the screen.
  10. PSP 1000 LCD Screen Replacement: adım 10, 1 resimden 1.
    • The LCD screen is still attached with ribbon cables. Gently lift up the LCD screen so you do not break them.
  11. PSP 1000 LCD Screen Replacement: adım 11, 3 resimden 1. PSP 1000 LCD Screen Replacement: adım 11, 3 resimden 2. PSP 1000 LCD Screen Replacement: adım 11, 3 resimden 3.
    • The thin Ribbon Cable opens from the opposite side in which the Ribbon Cable enters. Open up the latch towards the Ribbon Cable. The latch will pull up and release the ribbon cable. Put your tool behind the black part, then pry up the black piece of plastic.
    • The wide Ribbon Cable opens from the same side in which the Ribbon Cable attatches, and opens away from the cable.
    • Both of these latches are the black pieces.
    • Gently pull the ribbon cables away from the latches. The LCD screen can now be removed.
    • When reassembling - be careful which way you push the latches. The small one is very easy to break.
Bitiş Çizgisi
70 farklı kişi bu kılavuzu tamamladı.
Henry Lee
794 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-6, Forte Winter 2010 Cal Poly, Team 5-6, Forte Winter 2010 üyesi
CPSU-FORTE-W10S5G6
5 Üyeler
22 adet Kılavuz yazıldı
8 Yorum
I broke one of the laches....helppp!!!!
janet - Yanıt
This is not easy...I tore up the outer casing trying to do this. I better see money in the mail for this
Justin Autrey - Yanıt
My Sony PSP has just stop coming on
lil bao - Yanıt
People!! If you weren't gifted in screws and bolts, then bring your console to a repair shop. Seriously blaming this for your Dick Fingers?
janisfranckevics - Yanıt
dick fingers!!
jonathon allen - Yanıt
It needs to be mentioned that the power switch is very fragile. When reassembling the front cover you need to first make sure that the small black switch on the circuit board sits in the yellow part of the switch, otherwise when you apply pressure to click the cover back in place the black switch will break off.
Isak - Yanıt
Great tutorial, thanks to this I manage to fix the R button, it turns out the ribbon cable of the right section of buttons was dirty and a little bit off of place, and taking out the screen was necessary to get to that connector.
Jhosttyn Medina - Yanıt
Totally helpful thank u so much, a little bit of patience and common sense job was done an I was play my psp portable the instant I put the battery cover back on it! U guys ROCK TNX AGIAN!!
Barclay Wilson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 30
Son 7 gün: 138
Son 30 gün: 634
Her zaman: 79,828
