Ana içeriğe geç
PSP 1000 Motherboard Replacement
Görüntüleme: 26 B
İstatistikleri görüntüle:
Son 24 Saat:
20
Son 7 Gün:
198
Son 30 Gün:
793
Her zaman:
26.009
Yorumlar: 2
2 comments on steps.
Tamamlandı: 11
11 kişi bu kılavuzu "tamamlandı" olarak işaretledi. Sıradaki sen olacak mısın?
Sık Kullanılanlar: 4
4 kişi bu kılavuzu favorilerine ekledi (ve abone oldu). Sıradaki sen olacak mısın?
Gerekli Süre: 40 dakika - 1 saat
Zorluk: Kolay
In this guide I will be going through a detailed step by step process on how to replace your PSP 1000 motherboard. There is no prior experience required in order to begin this replacement as it is very short and simple. The PSP 1000 was first released in 2005 and as many years have passed this device has aged poorly. The main purpose for this guide is to replace a damaged or time worn motherboard that needs replacing as the device itself is ahead of its time, yet the parts have aged 16 years. Have an empty desk along with the tools required for an easy and simple breakdown of your device. Thoroughly read the steps and operate on your device with the specified tools.
Neye ihtiyacın var
Aletler
    1. PSP 1000 Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. PSP 1000 Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
      • Remove any external cables from the device and place the device face down on a flat surface.
      FixBot'a Sor
      Yorum Ekle
    2. PSP 1000 Motherboard Replacement: adım 2, 2 resimden 1. PSP 1000 Motherboard Replacement: adım 2, 2 resimden 2.
      • Remove the battery door cover located on the left hand side.
      • Remove the battery from the device.
      FixBot'a Sor
      Yorum Ekle
    3. PSP 1000 Motherboard Replacement: adım 3, 1 resimden 1.
      • Using a flat tool, remove the warranty sticker. Removing this sticker will expose two screws.
      FixBot'a Sor
      Yorum Ekle
    4. PSP 1000 Motherboard Replacement: adım 4, 3 resimden 1. PSP 1000 Motherboard Replacement: adım 4, 3 resimden 2. PSP 1000 Motherboard Replacement: adım 4, 3 resimden 3.
      • Using a Phillips #00 screwdriver, remove the two black 5.2 mm screws marked in red.
      • Remove the two silver 2.4 mm screws marked in orange.
      • Remove the silver 4.4 mm screw marked in yellow at the bottom of the case.
      • Remove the two black 5.4 mm screws marked in green on the back of the case.
      FixBot'a Sor
      Yorum Ekle
    5. PSP 1000 Motherboard Replacement: adım 5, 3 resimden 1. PSP 1000 Motherboard Replacement: adım 5, 3 resimden 2. PSP 1000 Motherboard Replacement: adım 5, 3 resimden 3.
      • Use a plastic opening tool to gently pry the face plate off of the device.
      • Be gentle when prying the face plate as you do not want to crack or scratch it.
      FixBot'a Sor
      Yorum Ekle
    6. PSP 1000 Motherboard Replacement: adım 6, 3 resimden 1. PSP 1000 Motherboard Replacement: adım 6, 3 resimden 2. PSP 1000 Motherboard Replacement: adım 6, 3 resimden 3.
      • Remove the top left and right trigger buttons by simply pulling them out.
      FixBot'a Sor
      Yorum Ekle
    7. PSP 1000 Motherboard Replacement: adım 7, 2 resimden 1. PSP 1000 Motherboard Replacement: adım 7, 2 resimden 2.
      • Using a plastic opening tool, lift the left side of the bottom circuit that includes the home, start, pause, and volume buttons.
      FixBot'a Sor
      Yorum Ekle
    8. PSP 1000 Motherboard Replacement: adım 8, 1 resimden 1.
      • Disconnect the zero-insertion force (ZIF) connector by unlocking the locking tab with a plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    9. PSP 1000 Motherboard Replacement: adım 9, 3 resimden 1. PSP 1000 Motherboard Replacement: adım 9, 3 resimden 2. PSP 1000 Motherboard Replacement: adım 9, 3 resimden 3.
      • Using a plastic opening tool, lift the LCD screen from in between the metal brackets.
      • Start at the bottom of the screen for an efficient removal.
      • Be very careful as the screen is very fragile.
      FixBot'a Sor
      Yorum Ekle
    10. PSP 1000 Motherboard Replacement: adım 10, 3 resimden 1. PSP 1000 Motherboard Replacement: adım 10, 3 resimden 2. PSP 1000 Motherboard Replacement: adım 10, 3 resimden 3.
      • Use the plastic opening tool to unlock all the ribbon cables attached from the LCD screen to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    11. PSP 1000 Motherboard Replacement: adım 11, 3 resimden 1. PSP 1000 Motherboard Replacement: adım 11, 3 resimden 2. PSP 1000 Motherboard Replacement: adım 11, 3 resimden 3.
      • Using the Phillips #00 screwdriver, remove the two silver 4.2mm screws marked in red.
      • Remove the three silver 3mm screws marked in orange.
      • Remove the black 4.2mm screw marked in yellow.
      FixBot'a Sor
      Yorum Ekle
    12. PSP 1000 Motherboard Replacement: adım 12, 2 resimden 1. PSP 1000 Motherboard Replacement: adım 12, 2 resimden 2.
      • Once all screws are removed, gently lift the metal cage from the bottom.
      • If there is resistance, slide the open button on top of the device as it may be latched to the cage.
      FixBot'a Sor
      Yorum Ekle
    13. PSP 1000 Motherboard Replacement, Note the conductive piece: adım 13, 3 resimden 1. PSP 1000 Motherboard Replacement, Note the conductive piece: adım 13, 3 resimden 2. PSP 1000 Motherboard Replacement, Note the conductive piece: adım 13, 3 resimden 3.
      • The midframe has a rectangular conductive piece that can fall out and be lost. Without it, the joystick won't work. Make sure to reinsert it so that the contacts on the conductive piece touches the pads.
      FixBot'a Sor
      Yorum Ekle
    14. PSP 1000 Motherboard Replacement: adım 14, 3 resimden 1. PSP 1000 Motherboard Replacement: adım 14, 3 resimden 2. PSP 1000 Motherboard Replacement: adım 14, 3 resimden 3.
      • Remove the single 4.4mm screw that holds the D-Pad in place using the Phillips #00 screwdriver.
      • Underneath the D-Pad, unlock the ZIF connector holding the ribbon cable in place using the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    15. PSP 1000 Motherboard Replacement: adım 15, 3 resimden 1. PSP 1000 Motherboard Replacement: adım 15, 3 resimden 2. PSP 1000 Motherboard Replacement: adım 15, 3 resimden 3.
      • Using a plastic opening tool, unlock the small black clip that is located underneath the circuit board.
      FixBot'a Sor
      Yorum Ekle
    16. PSP 1000 Motherboard Replacement: adım 16, 3 resimden 1. PSP 1000 Motherboard Replacement: adım 16, 3 resimden 2. PSP 1000 Motherboard Replacement: adım 16, 3 resimden 3.
      • Using a plastic opening tool, remove the steel bracket under the right trigger.
      FixBot'a Sor
      Yorum Ekle
    17. PSP 1000 Motherboard Replacement: adım 17, 2 resimden 1. PSP 1000 Motherboard Replacement: adım 17, 2 resimden 2.
      • Use the plastic opening tool to unlock all of the ZIF connectors and disconnect all cables from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    18. PSP 1000 Motherboard Replacement: adım 18, 3 resimden 1. PSP 1000 Motherboard Replacement: adım 18, 3 resimden 2. PSP 1000 Motherboard Replacement: adım 18, 3 resimden 3.
      • Using a plastic opening tool, unclip the cable from the circuit and begin to remove any tape securing any cables.
      • Remove the single 1.5 mm screw on the bottom right of the power input using the Phillips #00 screwdriver to remove the cable.
      FixBot'a Sor
      Yorum Ekle
    19. PSP 1000 Motherboard Replacement: adım 19, 3 resimden 1. PSP 1000 Motherboard Replacement: adım 19, 3 resimden 2. PSP 1000 Motherboard Replacement: adım 19, 3 resimden 3.
      • Above the charging input cable is the wireless antenna. Gently lift and place the wireless antenna on the left-hand side as it cannot be completely removed.
      FixBot'a Sor
      Yorum Ekle
    20. PSP 1000 Motherboard Replacement: adım 20, 3 resimden 1. PSP 1000 Motherboard Replacement: adım 20, 3 resimden 2. PSP 1000 Motherboard Replacement: adım 20, 3 resimden 3.
      • Remove the speaker cables highlighted on the bottom middle by removing any tape.
      • Using a flat tool unclip the cables from the motherboard along with the ribbon cable on the right.
      FixBot'a Sor
      Yorum Ekle
    21. PSP 1000 Motherboard Replacement: adım 21, 3 resimden 1. PSP 1000 Motherboard Replacement: adım 21, 3 resimden 2. PSP 1000 Motherboard Replacement: adım 21, 3 resimden 3.
      • Using your fingers or a plastic opening tool, slide the UMD drive ribbon cable from the lock to release it.
      FixBot'a Sor
      Yorum Ekle
    22. PSP 1000 Motherboard Replacement: adım 22, 3 resimden 1. PSP 1000 Motherboard Replacement: adım 22, 3 resimden 2. PSP 1000 Motherboard Replacement: adım 22, 3 resimden 3.
      • Using the Phillips #00 screwdriver, remove the single 4.4 mm screw located on the top right of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    23. PSP 1000 Motherboard Replacement: adım 23, 3 resimden 1. PSP 1000 Motherboard Replacement: adım 23, 3 resimden 2. PSP 1000 Motherboard Replacement: adım 23, 3 resimden 3.
      • Gently lift the motherboard up and away to remove it from the device.
      • Carefully and slowly remove the motherboard as you do not want to damage anything caught onto the board.
      FixBot'a Sor
      Yorum Ekle
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Yazar
ile
Faraz Rashid
629 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 20
Son 7 gün: 198
Son 30 gün: 793
Her zaman: 26,009
