Ana içeriğe geç
PSP 2000 Front Casing Replacement
Neye ihtiyacın var
  1. PSP 2000 Front Casing Replacement, Battery: adım 1, 3 resimden 1. PSP 2000 Front Casing Replacement, Battery: adım 1, 3 resimden 2. PSP 2000 Front Casing Replacement, Battery: adım 1, 3 resimden 3.
    • Place PSP face down, so that the UMD Drive is facing upwards.
    • Locate the battery door and open.
    • Remove the battery from inside.
    FixBot'a Sor
    Yorum Ekle
  2. PSP 2000 Front Casing Replacement, Front Casing: adım 2, 1 resimden 1.
    • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
    • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
    • Remove the sticker using the PSP Opening Tools.
    • Under the sticker is a 5mm Phillips screw needed in the next step.
    FixBot'a Sor
    Yorum Ekle
  3. PSP 2000 Front Casing Replacement: adım 3, 2 resimden 1. PSP 2000 Front Casing Replacement: adım 3, 2 resimden 2.
    • Remove four 5 mm Phillips from the case.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    FixBot'a Sor
    Yorum Ekle
  4. PSP 2000 Front Casing Replacement: adım 4, 2 resimden 1. PSP 2000 Front Casing Replacement: adım 4, 2 resimden 2.
    • Remove the following screws from around the bezel:
    • Two 4 mm Phillips
    • One 5 mm Phillips
    • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
    FixBot'a Sor
    Yorum Ekle
  5. PSP 2000 Front Casing Replacement: adım 5, 2 resimden 1. PSP 2000 Front Casing Replacement: adım 5, 2 resimden 2.
    • Gently pry the front bezel away from the casing using a PSP opening tool.
    • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
    • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
    FixBot'a Sor
    Yorum Ekle
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
pepe32290
1.772 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-3, Maness Fall 2009 Cal Poly, Team 6-3, Maness Fall 2009 üyesi
CPSU-MANESS-F09S6G3
5 Üyeler
48 adet Kılavuz yazıldı
2Kılavuz Yorumları
Does the front casing also have the plastic glass screen on it as well? Or is that separate?
Arthur - Yanıt Paylaş
sorry this is a decade too late HA. i just did a swap for the plastic screen cover and yes, for anyone in the future, the plastic cover is on the front shell piece, you will need some tweezers or something narrow to get the plastic screen popped off, dont crack the front shell, the bottom gets fragile so just be slow and methodical. but its an easy swap, maybe 15 minutes. good time to clear out the lint around the joystick as well.
Scott Munier - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 58
Son 30 gün: 275
Her zaman: 32,327
