Ana içeriğe geç
PSP 300x D-Pad Replacement
Neye ihtiyacın var
  1. PSP 300x D-Pad Replacement, Battery: adım 1, 3 resimden 1. PSP 300x D-Pad Replacement, Battery: adım 1, 3 resimden 2. PSP 300x D-Pad Replacement, Battery: adım 1, 3 resimden 3.
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
  2. PSP 300x D-Pad Replacement, Casing: adım 2, 1 resimden 1.
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
  3. PSP 300x D-Pad Replacement: adım 3, 2 resimden 1. PSP 300x D-Pad Replacement: adım 3, 2 resimden 2.
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
  4. PSP 300x D-Pad Replacement: adım 4, 1 resimden 1.
    • Next, unscrew the two screws located at the top of the PSP.
  5. PSP 300x D-Pad Replacement: adım 5, 1 resimden 1.
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
  6. PSP 300x D-Pad Replacement: adım 6, 2 resimden 1. PSP 300x D-Pad Replacement: adım 6, 2 resimden 2.
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
  7. PSP 300x D-Pad Replacement, D-Pad: adım 7, 2 resimden 1. PSP 300x D-Pad Replacement, D-Pad: adım 7, 2 resimden 2.
    • Peal up the rubber pad that is securing the D-pad buttons to the backside of the front casing.
    • Remove the D-pad and the rubber piece.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
mbnewsom
3.082 İtibar
11 adet Kılavuz yazıldı
Bir Yorum
Is it for 2000?
Kaio Igor - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 22
Son 30 gün: 88
Her zaman: 8,901
