Ana içeriğe geç
PSP 300x Front Casing Replacement
Neye ihtiyacın var
  1. PSP 300x Front Casing Replacement, Battery: adım 1, 3 resimden 1. PSP 300x Front Casing Replacement, Battery: adım 1, 3 resimden 2. PSP 300x Front Casing Replacement, Battery: adım 1, 3 resimden 3.
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
    FixBot'a Sor
    Yorum Ekle
  2. PSP 300x Front Casing Replacement, Front Casing: adım 2, 1 resimden 1.
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
    FixBot'a Sor
    Yorum Ekle
  3. PSP 300x Front Casing Replacement: adım 3, 2 resimden 1. PSP 300x Front Casing Replacement: adım 3, 2 resimden 2.
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
    FixBot'a Sor
    Yorum Ekle
  4. PSP 300x Front Casing Replacement: adım 4, 1 resimden 1.
    • Next, unscrew the two screws located at the top of the PSP.
    FixBot'a Sor
    Yorum Ekle
  5. PSP 300x Front Casing Replacement: adım 5, 1 resimden 1.
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
    FixBot'a Sor
    Yorum Ekle
  6. PSP 300x Front Casing Replacement: adım 6, 2 resimden 1. PSP 300x Front Casing Replacement: adım 6, 2 resimden 2.
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
    FixBot'a Sor
    Yorum Ekle
Sonuç
33 farklı kişi bu kılavuzu tamamladı.
kbrunner
96 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 19-2, Maness Fall 2009 Cal Poly, Team 19-2, Maness Fall 2009 üyesi
CPSU-MANESS-F09S19G2
3 Üyeler
13 adet Kılavuz yazıldı
1Rehber Yorum
This is only the faceplate, not a casing replacement, come on
Dick - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 16
Son 7 gün: 73
Son 30 gün: 300
Her zaman: 24,018
