Ana içeriğe geç
PSP 300x Trigger Buttons Replacement
Neye ihtiyacın var
  1. PSP 300x Trigger Buttons Replacement, Battery: adım 1, 3 resimden 1. PSP 300x Trigger Buttons Replacement, Battery: adım 1, 3 resimden 2. PSP 300x Trigger Buttons Replacement, Battery: adım 1, 3 resimden 3.
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
    FixBot'a Sor
    Yorum Ekle
  2. PSP 300x Trigger Buttons Replacement, Front Casing: adım 2, 1 resimden 1.
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
    FixBot'a Sor
    Yorum Ekle
  3. PSP 300x Trigger Buttons Replacement: adım 3, 2 resimden 1. PSP 300x Trigger Buttons Replacement: adım 3, 2 resimden 2.
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
    FixBot'a Sor
    Yorum Ekle
  4. PSP 300x Trigger Buttons Replacement: adım 4, 1 resimden 1.
    • Next, unscrew the two screws located at the top of the PSP.
    FixBot'a Sor
    Yorum Ekle
  5. PSP 300x Trigger Buttons Replacement: adım 5, 1 resimden 1.
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
    FixBot'a Sor
    Yorum Ekle
  6. PSP 300x Trigger Buttons Replacement: adım 6, 2 resimden 1. PSP 300x Trigger Buttons Replacement: adım 6, 2 resimden 2.
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
    FixBot'a Sor
    Yorum Ekle
  7. PSP 300x Trigger Buttons Replacement, LCD Screen: adım 7, 2 resimden 1. PSP 300x Trigger Buttons Replacement, LCD Screen: adım 7, 2 resimden 2.
    • Push the homebar to the right to release the tab located on the right side of the LCD screen.
    • DO NOT completely remove the homebar, as it is still connected by ribbon cables.
    FixBot'a Sor
    Yorum Ekle
  8. PSP 300x Trigger Buttons Replacement: adım 8, 3 resimden 1. PSP 300x Trigger Buttons Replacement: adım 8, 3 resimden 2. PSP 300x Trigger Buttons Replacement: adım 8, 3 resimden 3.
    • Slowly lift the LCD screen off the PSP starting at the top edge corner.
    • Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
    • Orientation of PSP is flipped in photo.
    FixBot'a Sor
    Yorum Ekle
  9. PSP 300x Trigger Buttons Replacement: adım 9, 2 resimden 1. PSP 300x Trigger Buttons Replacement: adım 9, 2 resimden 2.
    • Flip the small brown locks on the four ribbon cable connectors up using a spudger or fingernail.
    • Pull all four ribbon cables out.
    • Now remove the LCD screen and homebar from the PSP.
    FixBot'a Sor
    Yorum Ekle
  10. PSP 300x Trigger Buttons Replacement: adım 10, 1 resimden 1.
    • Remove the metal tab that lies above the LCD screen.
    • Upon reassembly, make note that the stamped lettering faces down, and the large tab fits just above the motherboard to the right hand side of the left trigger.
    FixBot'a Sor
    Yorum Ekle
  11. PSP 300x Trigger Buttons Replacement, Trigger Buttons: adım 11, 1 resimden 1.
    • Remove the screw securing 'L' trigger to the PSP.
    FixBot'a Sor
    Yorum Ekle
  12. PSP 300x Trigger Buttons Replacement: adım 12, 1 resimden 1.
    • Remove the white plastic piece that holds the 'L' trigger in place.
    FixBot'a Sor
    Yorum Ekle
  13. PSP 300x Trigger Buttons Replacement: adım 13, 1 resimden 1.
    • Remove the 'L' trigger from the PSP.
    FixBot'a Sor
    Yorum Ekle
  14. PSP 300x Trigger Buttons Replacement: adım 14, 1 resimden 1.
    • Remove the screw securing the 'R' trigger.
    FixBot'a Sor
    Yorum Ekle
  15. PSP 300x Trigger Buttons Replacement: adım 15, 1 resimden 1.
    • Remove the white plastic piece that holds the 'R' trigger in place.
    FixBot'a Sor
    Yorum Ekle
  16. PSP 300x Trigger Buttons Replacement: adım 16, 1 resimden 1.
    • Remove the 'R' trigger from the PSP.
    FixBot'a Sor
    Yorum Ekle
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
cmcevill
541 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 19-2, Maness Fall 2009 Cal Poly, Team 19-2, Maness Fall 2009 üyesi
CPSU-MANESS-F09S19G2
3 Üyeler
13 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 51
Son 30 gün: 256
Her zaman: 24,526
