Ana içeriğe geç
PSP 300xc Trigger Buttons Replacement
Neye ihtiyacın var
  1. PSP 300xc Trigger Buttons Replacement, Battery: adım 1, 2 resimden 1. PSP 300xc Trigger Buttons Replacement, Battery: adım 1, 2 resimden 2.
    • Press the button securing the battery door to the PSP 300xc, and lift the battery door off.
    • Lift the battery out of the PSP.
  2. PSP 300xc Trigger Buttons Replacement, Front Case: adım 2, 1 resimden 1.
    • Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
  3. PSP 300xc Trigger Buttons Replacement: adım 3, 2 resimden 1. PSP 300xc Trigger Buttons Replacement: adım 3, 2 resimden 2.
    • Remove four Phillips screws from the back of the PSP.
  4. PSP 300xc Trigger Buttons Replacement: adım 4, 1 resimden 1.
    • Remove two Phillips screws from the top of the PSP.
  5. PSP 300xc Trigger Buttons Replacement: adım 5, 1 resimden 1.
    • Remove a single screw from the bottom edge of the PSP.
  6. PSP 300xc Trigger Buttons Replacement: adım 6, 2 resimden 1. PSP 300xc Trigger Buttons Replacement: adım 6, 2 resimden 2.
    • Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it.
  7. PSP 300xc Trigger Buttons Replacement, LCD: adım 7, 1 resimden 1.
    • Remove a single Phillips screw securing the home bar to the PSP 300xc.
  8. PSP 300xc Trigger Buttons Replacement: adım 8, 2 resimden 1. PSP 300xc Trigger Buttons Replacement: adım 8, 2 resimden 2.
    • Push the home bar to the right about 1cm to release a tab, and begin to lift the right end of the home bar slightly.
    • Do not attempt to remove the home bar yet, it is still attached to the PSP 300xc.
  9. PSP 300xc Trigger Buttons Replacement: adım 9, 1 resimden 1.
    • Insert a spudger under the LCD, beside the black plastic tab.
    • Push the LCD to the left and pry up to release the left edge of the LCD from under the plastic tab.
  10. PSP 300xc Trigger Buttons Replacement: adım 10, 1 resimden 1.
    • Push the LCD to the right and pry up to release the right edge of the LCD from under the plastic tab.
  11. PSP 300xc Trigger Buttons Replacement: adım 11, 3 resimden 1. PSP 300xc Trigger Buttons Replacement: adım 11, 3 resimden 2. PSP 300xc Trigger Buttons Replacement: adım 11, 3 resimden 3.
    • Rotate the LCD away from the PSP to reveal the LCD and home bar ribbon cables.
    • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following four ZIF connectors:
    • Home bar cable
    • Microphone cable
    • LCD display data cable
    • Touchscreen cable
    • Be sure you are prying up on the retaining flap, not the socket itself
    • After flipping up the locking tabs on all four connectors, use your fingers or a spudger to gently pull the cables straight out of the connectors.
  12. PSP 300xc Trigger Buttons Replacement: adım 12, 1 resimden 1.
    • Remove the LCD from the PSP 300xc.
  13. PSP 300xc Trigger Buttons Replacement, Home Bar: adım 13, 3 resimden 1. PSP 300xc Trigger Buttons Replacement, Home Bar: adım 13, 3 resimden 2. PSP 300xc Trigger Buttons Replacement, Home Bar: adım 13, 3 resimden 3.
    • Lift the home bar up as high as it will go, but not so high that the wires disconnect.
    • Try to bend the small tab under the silver rim as little as possible it the following steps. The more you bend, the more likely it will snap.
    • Twist the home bar counter clockwise while carefully lifting it further. The left edge has to lift over the black plastic frame to allow it to rotate.
    • The home bar should now lift out of the PSP 300xc.
  14. PSP 300xc Trigger Buttons Replacement, Trigger Buttons: adım 14, 2 resimden 1. PSP 300xc Trigger Buttons Replacement, Trigger Buttons: adım 14, 2 resimden 2.
    • Remove both trigger buttons by lifting them off the PSP 300xc.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Matthew Newsom
41.972 İtibar
67 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 39
Her zaman: 2,913
