Ana içeriğe geç
PSP 300xc UMD Door Replacement
Neye ihtiyacın var
  1. PSP 300xc UMD Door Replacement, Battery: adım 1, 2 resimden 1. PSP 300xc UMD Door Replacement, Battery: adım 1, 2 resimden 2.
    • Press the button securing the battery door to the PSP 300xc, and lift the battery door off.
    • Lift the battery out of the PSP.
  2. PSP 300xc UMD Door Replacement, Front Case: adım 2, 1 resimden 1.
    • Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
  3. PSP 300xc UMD Door Replacement: adım 3, 2 resimden 1. PSP 300xc UMD Door Replacement: adım 3, 2 resimden 2.
    • Remove four Phillips screws from the back of the PSP.
  4. PSP 300xc UMD Door Replacement: adım 4, 1 resimden 1.
    • Remove two Phillips screws from the top of the PSP.
  5. PSP 300xc UMD Door Replacement: adım 5, 1 resimden 1.
    • Remove a single screw from the bottom edge of the PSP.
  6. PSP 300xc UMD Door Replacement: adım 6, 2 resimden 1. PSP 300xc UMD Door Replacement: adım 6, 2 resimden 2.
    • Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it.
  7. PSP 300xc UMD Door Replacement, LCD: adım 7, 1 resimden 1.
    • Remove a single Phillips screw securing the home bar to the PSP 300xc.
  8. PSP 300xc UMD Door Replacement: adım 8, 2 resimden 1. PSP 300xc UMD Door Replacement: adım 8, 2 resimden 2.
    • Push the home bar to the right about 1cm to release a tab, and begin to lift the right end of the home bar slightly.
    • Do not attempt to remove the home bar yet, it is still attached to the PSP 300xc.
  9. PSP 300xc UMD Door Replacement: adım 9, 1 resimden 1.
    • Insert a spudger under the LCD, beside the black plastic tab.
    • Push the LCD to the left and pry up to release the left edge of the LCD from under the plastic tab.
  10. PSP 300xc UMD Door Replacement: adım 10, 1 resimden 1.
    • Push the LCD to the right and pry up to release the right edge of the LCD from under the plastic tab.
  11. PSP 300xc UMD Door Replacement: adım 11, 3 resimden 1. PSP 300xc UMD Door Replacement: adım 11, 3 resimden 2. PSP 300xc UMD Door Replacement: adım 11, 3 resimden 3.
    • Rotate the LCD away from the PSP to reveal the LCD and home bar ribbon cables.
    • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following four ZIF connectors:
    • Home bar cable
    • Microphone cable
    • LCD display data cable
    • Touchscreen cable
    • Be sure you are prying up on the retaining flap, not the socket itself
    • After flipping up the locking tabs on all four connectors, use your fingers or a spudger to gently pull the cables straight out of the connectors.
  12. PSP 300xc UMD Door Replacement: adım 12, 1 resimden 1.
    • Remove the LCD from the PSP 300xc.
  13. PSP 300xc UMD Door Replacement, Home Bar: adım 13, 3 resimden 1. PSP 300xc UMD Door Replacement, Home Bar: adım 13, 3 resimden 2. PSP 300xc UMD Door Replacement, Home Bar: adım 13, 3 resimden 3.
    • Lift the home bar up as high as it will go, but not so high that the wires disconnect.
    • Try to bend the small tab under the silver rim as little as possible it the following steps. The more you bend, the more likely it will snap.
    • Twist the home bar counter clockwise while carefully lifting it further. The left edge has to lift over the black plastic frame to allow it to rotate.
    • The home bar should now lift out of the PSP 300xc.
  14. PSP 300xc UMD Door Replacement, UMD Brace: adım 14, 1 resimden 1.
    • Using the flat edge of a spudger, pry the power board away from the PSP 300xc.
  15. PSP 300xc UMD Door Replacement: adım 15, 1 resimden 1.
    • Lift the right silver rim up and off the PSP 300xc.
  16. PSP 300xc UMD Door Replacement: adım 16, 1 resimden 1.
    • Using the pointed end of a spudger, pull the UMD door spring to the left, and remove it from the PSP.
  17. PSP 300xc UMD Door Replacement: adım 17, 3 resimden 1. PSP 300xc UMD Door Replacement: adım 17, 3 resimden 2. PSP 300xc UMD Door Replacement: adım 17, 3 resimden 3.
    • Use your fingernail or the edge of a spudger to flip up the retaining flap on the UMD drive ribbon socket.
    • Use your fingernail or tip of a spudger to push both sides of the black retaining flap on the UMD laser ribbon socket to the right.
    • Use a spudger to gently pull both ribbon cables straight out of their sockets.
  18. PSP 300xc UMD Door Replacement: adım 18, 2 resimden 1. PSP 300xc UMD Door Replacement: adım 18, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Flip the PSP 300xc over and open the UMD door.
    • Using a pair of tweezers, grab the small rubber square between the metal UMD brace and case, and lift it out of the PSP 300xc.
    • Repeat for the rubber square on the other side of the UMD door.
  19. PSP 300xc UMD Door Replacement: adım 19, 3 resimden 1. PSP 300xc UMD Door Replacement: adım 19, 3 resimden 2. PSP 300xc UMD Door Replacement: adım 19, 3 resimden 3.
    • Slide the UMD brace toward the top of the UMD door until the brace disconnects from the door. Remove the brace.
  20. PSP 300xc UMD Door Replacement, UMD Door: adım 20, 2 resimden 1. PSP 300xc UMD Door Replacement, UMD Door: adım 20, 2 resimden 2.
    • Bend the PSP 300xc case while pulling up on the right edge of the UMD door until the right edge lifts free.
    • Remove the UMD door.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Matthew Newsom
40.884 İtibar
67 adet Kılavuz yazıldı
1Rehber Yorum
wow! I really found the steps very easy and well presented Matt. Great stuff!!! I even replaced my UMD door, and normally I mess up, but not this time! You saved me! thanks
ceejay - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 62
Her zaman: 14,478
