Ana içeriğe geç
PSP E1000 Battery Replacement
Neye ihtiyacın var
  1. PSP E1000 Battery Replacement, Battery: adım 1, 2 resimden 1. PSP E1000 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • To start the replacement flip the device over
  2. PSP E1000 Battery Replacement: adım 2, 2 resimden 1. PSP E1000 Battery Replacement: adım 2, 2 resimden 2.
    • We are going to start by removing the back panel.
    • To do this open the panel and gently squeeze in the UMD tray until it pops up.
    • It should lay flat against the back panel while open if done correctly
  3. PSP E1000 Battery Replacement: adım 3, 2 resimden 1. PSP E1000 Battery Replacement: adım 3, 2 resimden 2.
    • Gently bend the back panel to free the hinge on the left.
    • Once it is popped out it should look like the second photo
    • The back panel can then be slid off
  4. PSP E1000 Battery Replacement: adım 5, 3 resimden 1. PSP E1000 Battery Replacement: adım 5, 3 resimden 2. PSP E1000 Battery Replacement: adım 5, 3 resimden 3.
    • Remove the screw with a #00 Philips and slide up the battery cover.
    • The battery can now be removed by pulling it out.
    • When reinstalling, it is useful to use a spudger to push the cable back in.
    • Congratulations you have replaced your PSP E1000's battery
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Caleb Pierce
1.250 İtibar
8 adet Kılavuz yazıldı
1Rehber Yorum
Haleakala,akama
Micheal Churchill - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 86
Son 30 gün: 382
Her zaman: 3,766
