Ana içeriğe geç
PSP E1000 UMD switch Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. PSP E1000 UMD switch Replacement, UMD switch: adım 1, 3 resimden 1. PSP E1000 UMD switch Replacement, UMD switch: adım 1, 3 resimden 2. PSP E1000 UMD switch Replacement, UMD switch: adım 1, 3 resimden 3.
    • If you haven't indication for inserted disk the problem probably is in UMD switch.
  2. PSP E1000 UMD switch Replacement: adım 2, 3 resimden 1. PSP E1000 UMD switch Replacement: adım 2, 3 resimden 2. PSP E1000 UMD switch Replacement: adım 2, 3 resimden 3.
    • Unhook the door metal plate and disassemble UMD door.
  3. PSP E1000 UMD switch Replacement: adım 3, 2 resimden 1. PSP E1000 UMD switch Replacement: adım 3, 2 resimden 2.
    • With a screwdriver I short the UMD switch to test the laser.
  4. PSP E1000 UMD switch Replacement: adım 4, 3 resimden 1. PSP E1000 UMD switch Replacement: adım 4, 3 resimden 2. PSP E1000 UMD switch Replacement: adım 4, 3 resimden 3.
    • Now let's disassemble it.
  5. PSP E1000 UMD switch Replacement: adım 5, 3 resimden 1. PSP E1000 UMD switch Replacement: adım 5, 3 resimden 2. PSP E1000 UMD switch Replacement: adım 5, 3 resimden 3.
    • Disconnect and remove the display.
  6. PSP E1000 UMD switch Replacement: adım 6, 2 resimden 1. PSP E1000 UMD switch Replacement: adım 6, 2 resimden 2.
    • I must disconnect 7x cables and unscrew a screw.
  7. PSP E1000 UMD switch Replacement: adım 7, 3 resimden 1. PSP E1000 UMD switch Replacement: adım 7, 3 resimden 2. PSP E1000 UMD switch Replacement: adım 7, 3 resimden 3.
    • Now I disconnect the battery connector and here is the mainboard.
  8. PSP E1000 UMD switch Replacement: adım 8, 2 resimden 1. PSP E1000 UMD switch Replacement: adım 8, 2 resimden 2.
    • I used soldering station to remove the old one and put the new one (UMD switch).
  9. PSP E1000 UMD switch Replacement: adım 9, 3 resimden 1. PSP E1000 UMD switch Replacement: adım 9, 3 resimden 2. PSP E1000 UMD switch Replacement: adım 9, 3 resimden 3.
    • Let's assemble and test it.
  10. PSP E1000 UMD switch Replacement: adım 10, 1 resimden 1.
    • And it works!
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
ZFix
191.308 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.535 adet Kılavuz yazıldı
Bir Yorum
Step 2 - picture number 3 is wrong, I broke off a little part of my PSP E1004. The left arrow points up but you have to pull it down, while trying to pry gently to the right. I learned the hard way after I managed to take it off.
Dukefazon - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 23
Son 30 gün: 114
Her zaman: 12,948
