Giriş
Use this guide to put a fresh analog joystick into the PSP Go!
Neye ihtiyacın var
Unscrew the four Phillips screws on the back of the PSP Go.
Rotate the PSP so you can see the top of the device.
Unscrew the two Phillips screws next to the volume buttons.
Remove the two Phillips screws holding the bottom plate.
Gently lift the bottom plate away from the device.
Use a #00 Phillips screwdriver to remove both screws holding the analog joystick in place.
6 farklı kişi bu kılavuzu tamamladı.
