Ana içeriğe geç
PSP Go Display Replacement
Neye ihtiyacın var
  1. PSP Go Display Replacement, Back Cover: adım 1, 2 resimden 1. PSP Go Display Replacement, Back Cover: adım 1, 2 resimden 2.
    • Unscrew the four Phillips screws on the back of the PSP Go.
    • Rotate the PSP so you can see the top of the device.
    • Unscrew the two Phillips screws next to the volume buttons.
  2. PSP Go Display Replacement: adım 2, 2 resimden 1. PSP Go Display Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
    • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
    • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
  3. PSP Go Display Replacement, Top Cover: adım 3, 1 resimden 1.
    • Pull the top cover upwards gently from its housing.
  4. PSP Go Display Replacement, Left Trigger: adım 4, 1 resimden 1.
    • Use a plastic opening tool to gently flip up the left trigger connector.
  5. PSP Go Display Replacement: adım 5, 2 resimden 1. PSP Go Display Replacement: adım 5, 2 resimden 2.
    • Unscrew the lone Phillips screw holding the trigger in place. Remove both trigger and retaining plate from the PSP Go.
    • If necessary, repeat steps 2 and 3 to remove the right trigger button.
  6. PSP Go Display Replacement, Battery: adım 6, 3 resimden 1. PSP Go Display Replacement, Battery: adım 6, 3 resimden 2. PSP Go Display Replacement, Battery: adım 6, 3 resimden 3.
    • Do not peel the sticker away from the left EMI shield. It will expose the "VOID VOID" lettering that will void your warranty!
    • Use the plastic opening tool to gently peel away at the "Warranty Void" sticker. Start on one edge, as shown, and slide the tool from side to side until the sticker is removed from just the battery.
  7. PSP Go Display Replacement: adım 7, 1 resimden 1.
    • Gently pull the sticker away from the battery connector, just enough so that the connector is visible.
    • Wedge a plastic opening tool in between the connector and logic board, and gently pull the connector upwards.
    • Make sure not to disconnect the white connector socket on the logic board, and just the connector itself.
  8. PSP Go Display Replacement: adım 8, 2 resimden 1. PSP Go Display Replacement: adım 8, 2 resimden 2.
    • Use a plastic opening tool to pop out the battery, being careful not to snag the "Warranty Void" sticker in the process.
    • When putting a new battery into the PSP Go, make sure you hold the "Warranty Sticker" so you don't put the battery on top of it.
  9. PSP Go Display Replacement, Logic Board: adım 9, 1 resimden 1.
    • Remove the single Phillips screw securing the logic board to the inner case.
  10. PSP Go Display Replacement: adım 10, 2 resimden 1. PSP Go Display Replacement: adım 10, 2 resimden 2.
    • Use a plastic opening tool to gently flip up the right trigger connector.
  11. PSP Go Display Replacement: adım 11, 2 resimden 1. PSP Go Display Replacement: adım 11, 2 resimden 2.
    • Use a #00 Phillips screwdriver to unscrew both bottom plate screws.
    • Remove the bottom plate by lifting it away from the device.
  12. PSP Go Display Replacement: adım 12, 1 resimden 1.
    • Remove both headphone jack and analog joystick screws using your #00 Phillips screwdriver.
  13. PSP Go Display Replacement: adım 13, 2 resimden 1. PSP Go Display Replacement: adım 13, 2 resimden 2.
    • Be very careful when disconnecting the following cables. The connectors do not have flip-up tabs; just hold each cable steady and pull it out of the connector.
    • Unplug the volume button cable using a pair of tweezers. Be careful not to damage the cable.
    • Unplug the Start/Select button cable the same way. Make sure to grasp the black plastic pull tab of the cable.
  14. PSP Go Display Replacement: adım 14, 1 resimden 1.
    • Use a pair of tweezers to pull out the battery's clear plastic cover.
    • Notice the little metal tab and slot (marked in red) where the clear plastic cover slides into. Make sure you slide the cover into place properly when reassembling the PSP Go.
  15. PSP Go Display Replacement: adım 15, 1 resimden 1.
    • The logic board is still connected to the display, so do not fully remove it from its housing!
    • Gently lift the logic board slightly out of its housing.
  16. PSP Go Display Replacement: adım 16, 2 resimden 1. PSP Go Display Replacement: adım 16, 2 resimden 2.
    • Use a plastic opening tool to disconnect the display cable from the logic board.
    • The D-pad may come loose while prying the logic board.
    • The logic board should now be free from the rest of the device.
    • During reassembly, make sure to properly line up the power button with the power button lever on the logic board.
  17. PSP Go Display Replacement, Display: adım 17, 1 resimden 1.
    • Use a #00 Phillips screwdriver to remove the four display screws.
  18. PSP Go Display Replacement: adım 18, 3 resimden 1. PSP Go Display Replacement: adım 18, 3 resimden 2. PSP Go Display Replacement: adım 18, 3 resimden 3.
    • Wedge a plastic opening tool in the location shown in the first picture, and slightly separate the metal frame from the plastic front panel.
    • Slide the plastic opening tool around the perimeter of the display, increasing the gap between the metal frame and the front panel.
    • The front panel should now be free from the metal frame. However, it is still connected to the frame, so don't remove it completely.
  19. PSP Go Display Replacement: adım 19, 2 resimden 1. PSP Go Display Replacement: adım 19, 2 resimden 2.
    • Use a plastic opening tool to disconnect the display cable from the rest of the device.
    • The PSP Go should now look similar to the second picture.
  20. PSP Go Display Replacement: adım 20, 2 resimden 1. PSP Go Display Replacement: adım 20, 2 resimden 2.
    • Be very careful when performing this procedure! If you put too much pressure on the display, you risk cracking it.
    • Wedge a plastic opening tool between the plastic front panel and display. Be very careful that you wedge it in the same location shown in the first picture.
    • Slide the plastic opening tool across the length of the display. This should loosen the glue binding the display to the plastic front panel.
    • Rotate the display 180 degrees and free the bottom side of the display in the same manner.
  21. PSP Go Display Replacement: adım 21, 1 resimden 1.
    • Gently separate the display from the front panel.
    • Match the orientation of the PSP logo on the display with the Sony logo on the front panel when reassembling the PSP Go.
Sonuç
24 farklı kişi bu kılavuzu tamamladı.
5 Yorum
Omg seriously!,,, Took this Dental Hygienist exactly one hour to do this! Awesome ! Thank you!
cyndiecote2006 - Yanıt
My psp won't turn back on please help I followed the directions exactly.
Daniel martinez - Yanıt
I use this guides to perform a flexible replacement because the original one is just too old and it's snapped some how, I've done it and my PSP Go work normal as before but I did make a mistake. I cracked the display. Yes it is really, really, really fragile! When he said “be very gentle/careful” he really mean it.
Learn from my mistakes, but I will fix it. Again.
HaKoSuKa GTR - Yanıt
Fantastic guide! I’ve been meaning to deep clean and replace the screen for an old PSP Go that a friend gave to me. The original screen had a few deep scratches, and the console itself was grimey from food or fizzy drink. Anyways super fresh now, and this guide was perfect!
LieinKing - Yanıt
I did it without the guide (I worked on my PSP Go before so I knew how to do it just based on my experience tearing it down and putting it back together) and now my PSP Go won't boot up.
Wflash00 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 59
Son 30 gün: 299
Her zaman: 58,435
