Ana içeriğe geç
PSP Go Gamepad Buttons Replacement
Neye ihtiyacın var
    1. PSP Go Gamepad Buttons Replacement, Back Cover: adım 1, 2 resimden 1. PSP Go Gamepad Buttons Replacement, Back Cover: adım 1, 2 resimden 2.
      • Unscrew the four Phillips screws on the back of the PSP Go.
      • Rotate the PSP so you can see the top of the device.
      • Unscrew the two Phillips screws next to the volume buttons.
      FixBot'a Sor
      Yorum Ekle
    2. PSP Go Gamepad Buttons Replacement: adım 2, 2 resimden 1. PSP Go Gamepad Buttons Replacement: adım 2, 2 resimden 2.
      • Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
      • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
      • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
      FixBot'a Sor
      Yorum Ekle
    1. PSP Go Gamepad Buttons Replacement, Top Cover: adım 3, 1 resimden 1.
      • Pull the top cover upwards gently from its housing.
      FixBot'a Sor
      Yorum Ekle
    1. PSP Go Gamepad Buttons Replacement, Left Trigger: adım 4, 1 resimden 1.
      • Use a plastic opening tool to gently flip up the left trigger connector.
      FixBot'a Sor
      Yorum Ekle
    2. PSP Go Gamepad Buttons Replacement: adım 5, 2 resimden 1. PSP Go Gamepad Buttons Replacement: adım 5, 2 resimden 2.
      • Unscrew the lone Phillips screw holding the trigger in place. Remove both trigger and retaining plate from the PSP Go.
      • If necessary, repeat steps 2 and 3 to remove the right trigger button.
      FixBot'a Sor
      Yorum Ekle
    1. PSP Go Gamepad Buttons Replacement, Battery: adım 6, 3 resimden 1. PSP Go Gamepad Buttons Replacement, Battery: adım 6, 3 resimden 2. PSP Go Gamepad Buttons Replacement, Battery: adım 6, 3 resimden 3.
      • Do not peel the sticker away from the left EMI shield. It will expose the "VOID VOID" lettering that will void your warranty!
      • Use the plastic opening tool to gently peel away at the "Warranty Void" sticker. Start on one edge, as shown, and slide the tool from side to side until the sticker is removed from just the battery.
      FixBot'a Sor
      Yorum Ekle
    2. PSP Go Gamepad Buttons Replacement: adım 7, 1 resimden 1.
      • Gently pull the sticker away from the battery connector, just enough so that the connector is visible.
      • Wedge a plastic opening tool in between the connector and logic board, and gently pull the connector upwards.
      • Make sure not to disconnect the white connector socket on the logic board, and just the connector itself.
      FixBot'a Sor
      Yorum Ekle
    3. PSP Go Gamepad Buttons Replacement: adım 8, 2 resimden 1. PSP Go Gamepad Buttons Replacement: adım 8, 2 resimden 2.
      • Use a plastic opening tool to pop out the battery, being careful not to snag the "Warranty Void" sticker in the process.
      • When putting a new battery into the PSP Go, make sure you hold the "Warranty Sticker" so you don't put the battery on top of it.
      FixBot'a Sor
      Yorum Ekle
    1. PSP Go Gamepad Buttons Replacement, Logic Board: adım 9, 1 resimden 1.
      • Remove the single Phillips screw securing the logic board to the inner case.
      FixBot'a Sor
      Yorum Ekle
    2. PSP Go Gamepad Buttons Replacement: adım 10, 2 resimden 1. PSP Go Gamepad Buttons Replacement: adım 10, 2 resimden 2.
      • Use a plastic opening tool to gently flip up the right trigger connector.
      FixBot'a Sor
      Yorum Ekle
    3. PSP Go Gamepad Buttons Replacement: adım 11, 2 resimden 1. PSP Go Gamepad Buttons Replacement: adım 11, 2 resimden 2.
      • Use a #00 Phillips screwdriver to unscrew both bottom plate screws.
      • Remove the bottom plate by lifting it away from the device.
      FixBot'a Sor
      Yorum Ekle
    4. PSP Go Gamepad Buttons Replacement: adım 12, 1 resimden 1.
      • Remove both headphone jack and analog joystick screws using your #00 Phillips screwdriver.
      FixBot'a Sor
      Yorum Ekle
    5. PSP Go Gamepad Buttons Replacement: adım 13, 2 resimden 1. PSP Go Gamepad Buttons Replacement: adım 13, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Be very careful when disconnecting the following cables. The connectors do not have flip-up tabs; just hold each cable steady and pull it out of the connector.
      • Unplug the volume button cable using a pair of tweezers. Be careful not to damage the cable.
      • Unplug the Start/Select button cable the same way. Make sure to grasp the black plastic pull tab of the cable.
      FixBot'a Sor
      Yorum Ekle
    6. PSP Go Gamepad Buttons Replacement: adım 14, 1 resimden 1.
      • Use a pair of tweezers to pull out the battery's clear plastic cover.
      • Notice the little metal tab and slot (marked in red) where the clear plastic cover slides into. Make sure you slide the cover into place properly when reassembling the PSP Go.
      FixBot'a Sor
      Yorum Ekle
    7. PSP Go Gamepad Buttons Replacement: adım 15, 1 resimden 1.
      • The logic board is still connected to the display, so do not fully remove it from its housing!
      • Gently lift the logic board slightly out of its housing.
      FixBot'a Sor
      Yorum Ekle
    8. PSP Go Gamepad Buttons Replacement: adım 16, 2 resimden 1. PSP Go Gamepad Buttons Replacement: adım 16, 2 resimden 2.
      • Use a plastic opening tool to disconnect the display cable from the logic board.
      • The D-pad may come loose while prying the logic board.
      • The logic board should now be free from the rest of the device.
      • During reassembly, make sure to properly line up the power button with the power button lever on the logic board.
      FixBot'a Sor
      Yorum Ekle
    1. PSP Go Gamepad Buttons Replacement, Gamepad Buttons: adım 17, 1 resimden 1.
      • Lift the gamepad buttons out of the PSP Go.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
So where is the step to take out the start and select button?
Anddy Ayala - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 27
Son 30 gün: 123
Her zaman: 15,787
