Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
This guide shows you how to remove the PSP Go's left trigger buttons.
  1. Use a plastic opening tool to gently flip up the left trigger connector.
    • Use a plastic opening tool to gently flip up the left trigger connector.
  2. Unscrew the lone Phillips screw holding the trigger in place. Remove both trigger and retaining plate from the PSP Go. If necessary, repeat steps 2 and 3 to remove the right trigger button.
    • Unscrew the lone Phillips screw holding the trigger in place. Remove both trigger and retaining plate from the PSP Go.
    • If necessary, repeat steps 2 and 3 to remove the right trigger button.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 1,285
