Ana içeriğe geç
PSP Go Trigger buttons Replacement
Neye ihtiyacın var
    1. PSP Go Trigger buttons Replacement, Back Cover: adım 1, 2 resimden 1. PSP Go Trigger buttons Replacement, Back Cover: adım 1, 2 resimden 2.
      • Unscrew the four Phillips screws on the back of the PSP Go.
      • Rotate the PSP so you can see the top of the device.
      • Unscrew the two Phillips screws next to the volume buttons.
      FixBot'a Sor
      Yorum Ekle
    2. PSP Go Trigger buttons Replacement: adım 2, 2 resimden 1. PSP Go Trigger buttons Replacement: adım 2, 2 resimden 2.
      • Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
      • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
      • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
      FixBot'a Sor
      Yorum Ekle
    1. PSP Go Trigger buttons Replacement, Top Cover: adım 3, 1 resimden 1.
      • Pull the top cover upwards gently from its housing.
      FixBot'a Sor
      Yorum Ekle
    1. PSP Go Trigger buttons Replacement, Trigger buttons: adım 4, 1 resimden 1.
      • The top cover will most likely come off during the repair, so might as well take it off now. Pull it upwards gently from its housing.
      FixBot'a Sor
      Yorum Ekle
    2. PSP Go Trigger buttons Replacement: adım 5, 1 resimden 1.
      • The procedure is exactly the same for the left trigger button.
      • Use a plastic opening tool to gently flip up the left trigger connector.
      FixBot'a Sor
      Yorum Ekle
    3. PSP Go Trigger buttons Replacement: adım 6, 2 resimden 1. PSP Go Trigger buttons Replacement: adım 6, 2 resimden 2.
      • Unscrew the lone Phillips screw holding the trigger in place. Remove both trigger and retaining plate from the PSP Go.
      • If necessary, repeat steps 2 and 3 to remove the right trigger button.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 30
Son 30 gün: 112
Her zaman: 13,174
