Ana içeriğe geç
PXN Arcade Stick Button Replacement
Neye ihtiyacın var
  1. PXN Arcade Stick Button Replacement, Buttons: adım 1, 1 resimden 1.
    • Place the PXN Arcade Stick on a flat surface.
  2. PXN Arcade Stick Button Replacement: adım 2, 1 resimden 1.
    • Turn the controller upside down.
    • Remove the four screws from the bottom of the device.
  3. PXN Arcade Stick Button Replacement: adım 3, 1 resimden 1.
    • Set the back cover aside, being cautious of the cable connected to the motherboard.
    • Unplug the controller converter plug.
  4. PXN Arcade Stick Button Replacement: adım 4, 1 resimden 1.
    • Unplug the button you wish to replace.
  5. PXN Arcade Stick Button Replacement: adım 5, 2 resimden 1. PXN Arcade Stick Button Replacement: adım 5, 2 resimden 2.
    • Push in and down on the button components.
  6. PXN Arcade Stick Button Replacement: adım 6, 2 resimden 1. PXN Arcade Stick Button Replacement: adım 6, 2 resimden 2.
    • Use a spudger to push in and up on the button housing.
  7. PXN Arcade Stick Button Replacement: adım 7, 1 resimden 1.
    • Line up the replacement button with the socket and push down.
  8. PXN Arcade Stick Button Replacement: adım 8, 1 resimden 1.
    • Push the new button down into the back case of the controller.
Sonuç
Derek Rosales
157 İtibar
1 Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 3-7, Harris Fall 2024 CSU Los Angeles, Team 3-7, Harris Fall 2024 üyesi
CSULA-HARRIS-F24S3G7
1 Üye
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 73
Son 30 gün: 303
Her zaman: 2,213
