Ana içeriğe geç
Pac-Man Connect and Play Joystick Switchboard Replacement
Neye ihtiyacın var
  1. Pac-Man Connect and Play Joystick Switchboard Replacement, Joystick Switchboard: adım 1, 2 resimden 1. Pac-Man Connect and Play Joystick Switchboard Replacement, Joystick Switchboard: adım 1, 2 resimden 2.
    • Flip over the device
    • Ensure the device has no power and is not plugged into a TV
  2. Pac-Man Connect and Play Joystick Switchboard Replacement: adım 2, 1 resimden 1.
    • Remove these 5 Phillips Head screws
  3. Pac-Man Connect and Play Joystick Switchboard Replacement: adım 3, 2 resimden 1. Pac-Man Connect and Play Joystick Switchboard Replacement: adım 3, 2 resimden 2.
    • You can now open the device
  4. Pac-Man Connect and Play Joystick Switchboard Replacement: adım 4, 1 resimden 1.
    • Remove these 2 screws (phillips)
  5. Pac-Man Connect and Play Joystick Switchboard Replacement: adım 5, 3 resimden 1. Pac-Man Connect and Play Joystick Switchboard Replacement: adım 5, 3 resimden 2. Pac-Man Connect and Play Joystick Switchboard Replacement: adım 5, 3 resimden 3.
    • You can now remove the board
    • You can, at this time, also remove the plastic X that holds the joystick spring in place.
Sonuç
Bir başkası bu kılavuzu tamamladı.
9021007
4.599 İtibar
25 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 533
