Ana içeriğe geç
Pac-Man Connect and Play Power Switch Replacement
Neye ihtiyacın var
  1. Pac-Man Connect and Play Power Switch Replacement, Power Switch: adım 1, 2 resimden 1. Pac-Man Connect and Play Power Switch Replacement, Power Switch: adım 1, 2 resimden 2.
    • Flip over the device
    • Ensure the device has no power, and isn't connected to a TV
  2. Pac-Man Connect and Play Power Switch Replacement: adım 2, 1 resimden 1.
    • Remove these 5 Phillips Head screws
  3. Pac-Man Connect and Play Power Switch Replacement: adım 3, 2 resimden 1. Pac-Man Connect and Play Power Switch Replacement: adım 3, 2 resimden 2.
    • You can now open the device
  4. Pac-Man Connect and Play Power Switch Replacement: adım 4, 2 resimden 1. Pac-Man Connect and Play Power Switch Replacement: adım 4, 2 resimden 2.
    • Remove these 2 screws (Phillips)
  5. Pac-Man Connect and Play Power Switch Replacement: adım 5, 2 resimden 1. Pac-Man Connect and Play Power Switch Replacement: adım 5, 2 resimden 2.
    • You can now lift away the power switch board
    • You can also now remove the power switch.
Sonuç
9021007
4.656 İtibar
25 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 449
