Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Pacific Cycle R4046WMB Chain Replacement
Neye ihtiyacın var
  1. Pacific Cycle R4046WMB Chain Replacement, Bicycle Chain: adım 1, 1 resimden 1.
    • Rotate the chain until the master link is in an accessible place.
    • The master link will be visually different from the rest of the links. It will have a gap next to one of the pins on each side, and it may be a different color.
  2. Pacific Cycle R4046WMB Chain Replacement: adım 2, 3 resimden 1. Pacific Cycle R4046WMB Chain Replacement: adım 2, 3 resimden 2. Pacific Cycle R4046WMB Chain Replacement: adım 2, 3 resimden 3.
    • Using one hand, pull the rear derailleur forward to create slack in the chain.
    • Using your other hand, lift the chain off of the front gears, setting it down on the "inside," between the gears and the bicycle's frame.
  3. Pacific Cycle R4046WMB Chain Replacement: adım 3, 3 resimden 1. Pacific Cycle R4046WMB Chain Replacement: adım 3, 3 resimden 2. Pacific Cycle R4046WMB Chain Replacement: adım 3, 3 resimden 3.
    • Disengage the master link by pushing the links on either side of it together.
    • If this is too difficult by hand, use a pair of needle nose pliers to squeeze pins of the master link together.
    • After the master link is disengaged, pull the chain apart by separating the two halves of the master link.
    • Pull the two halves of the master link out of each end of the chain, and set them aside.
  4. Pacific Cycle R4046WMB Chain Replacement: adım 4, 1 resimden 1.
    • Check which rear gear the chain is currently on; you'll need to remember this for reassembly.
    • Remove the chain from the bike by pulling it through the rear derailleur.
  5. Pacific Cycle R4046WMB Chain Replacement: adım 5, 1 resimden 1.
    • Thread the new chain through the front derailleur.
    • The front derailleur is the black metal loop above the gear.
  6. Pacific Cycle R4046WMB Chain Replacement: adım 6, 3 resimden 1. Pacific Cycle R4046WMB Chain Replacement: adım 6, 3 resimden 2. Pacific Cycle R4046WMB Chain Replacement: adım 6, 3 resimden 3.
    • Set the chain onto the same rear gear you removed the previous chain from earlier.
    • Thread the chain down and around the first derailleur gear...
    • ...then between the two derailleur gears...
    • ...then around the other derailleur gear.
    • Be sure to thread the chain through the chain guard, rather than over it.
  7. Pacific Cycle R4046WMB Chain Replacement: adım 7, 2 resimden 1. Pacific Cycle R4046WMB Chain Replacement: adım 7, 2 resimden 2.
    • Slide the pin of one of the master link halves through the end of one end of the chain.
    • Attach the other half to the other end in the opposite direction. ("From the front" on one end, and "from the back" on the other end.)
  8. Pacific Cycle R4046WMB Chain Replacement: adım 8, 2 resimden 1. Pacific Cycle R4046WMB Chain Replacement: adım 8, 2 resimden 2.
    • Slot the two halves of the master link together. One half's pin should go in the other's hole, and vice versa.
  9. Pacific Cycle R4046WMB Chain Replacement: adım 9, 3 resimden 1. Pacific Cycle R4046WMB Chain Replacement: adım 9, 3 resimden 2. Pacific Cycle R4046WMB Chain Replacement: adım 9, 3 resimden 3.
    • Hold the chain on either side of the master link, and pull them apart. The master link will snap in place, with each pin now in its "outer" hole rather than its "inner" hole
  10. Pacific Cycle R4046WMB Chain Replacement: adım 10, 3 resimden 1. Pacific Cycle R4046WMB Chain Replacement: adım 10, 3 resimden 2. Pacific Cycle R4046WMB Chain Replacement: adım 10, 3 resimden 3.
    • Pull the rear derailleur forward to create slack in the chain, just like in Step 1.
    • Set the chain onto the front gear.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 45
Her zaman: 1,748
