Ana içeriğe geç
Pacific Image Electronics CS3600 Bulb Panel Replacement
Neye ihtiyacın var
  1. Pacific Image Electronics CS3600 Bulb Panel Replacement, Bulb Panel: adım 1, 2 resimden 1. Pacific Image Electronics CS3600 Bulb Panel Replacement, Bulb Panel: adım 1, 2 resimden 2.
    • Start by removing the 5 screws that are 5mm x 9mm located on the bottom of the device with a J1 screwdriver.
  2. Pacific Image Electronics CS3600 Bulb Panel Replacement: adım 2, 1 resimden 1.
    • Now that the screws have been removed, carefully but firmly open up the device at the seam until it is presented as shown.
  3. Pacific Image Electronics CS3600 Bulb Panel Replacement: adım 3, 1 resimden 1.
    • Use a J0 screwdriver to remove the following four screws that are 5mm x 9mm.
  4. Pacific Image Electronics CS3600 Bulb Panel Replacement: adım 4, 1 resimden 1.
    • Use the same J0 screwdriver to remove the following 3 screws that are 7mm x 6mm.
  5. Pacific Image Electronics CS3600 Bulb Panel Replacement: adım 5, 1 resimden 1.
    • Now grab the plastic cover you just removed screws from and gently remove it from the device.
  6. Pacific Image Electronics CS3600 Bulb Panel Replacement: adım 6, 1 resimden 1.
    • You may now pick up the plastic covering you removed screws from in Step 3 with ease revealing the bulb.
  7. Pacific Image Electronics CS3600 Bulb Panel Replacement: adım 7, 1 resimden 1.
    • Lodge the plastic opening tool underneath the bulb casing. Using some upward force, pop the bulb off the casing.
  8. Pacific Image Electronics CS3600 Bulb Panel Replacement: adım 8, 1 resimden 1.
    • You have now removed the bulb from the casing. Gently pull the wires forward and prepare a soldering station.
  9. Pacific Image Electronics CS3600 Bulb Panel Replacement: adım 9, 1 resimden 1.
    • Carefully desolder the 2 wires from their solder contact points to detach the bulb panel from the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kristen Prince
201 İtibar
2 adet Kılavuz yazıldı
Ekip
Texas Tech, Team S46-G2, Bennett Spring 2017 Texas Tech, Team S46-G2, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S46G2
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 15
Her zaman: 332
