Ana içeriğe geç
Pacific Image Electronics CS3600 Lens Replacement
Neye ihtiyacın var
  1. Pacific Image Electronics CS3600 Lens Replacement, Lens: adım 1, 2 resimden 1. Pacific Image Electronics CS3600 Lens Replacement, Lens: adım 1, 2 resimden 2.
    • Use the J0 screwdriver to remove the 5 following screws that are 9 mm x 7 mm.
  2. Pacific Image Electronics CS3600 Lens Replacement: adım 2, 1 resimden 1.
    • Using light force open the device by pulling at the seam.
  3. Pacific Image Electronics CS3600 Lens Replacement: adım 3, 1 resimden 1.
    • Use the J0 screwdriver to remove the screws that are 7 mm x 6 mm.
  4. Pacific Image Electronics CS3600 Lens Replacement: adım 4, 1 resimden 1.
    • Once the screws are removed and casing removed the lens is revealed.
  5. Pacific Image Electronics CS3600 Lens Replacement: adım 5, 1 resimden 1.
    • Simply remove the lens and replace accordingly!
Sonuç
Kristen Prince
201 İtibar
2 adet Kılavuz yazıldı
Ekip
Texas Tech, Team S46-G2, Bennett Spring 2017 Texas Tech, Team S46-G2, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S46G2
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 15
Her zaman: 255
