Ana içeriğe geç
Pacific Image Electronics CS3600 Motor Replacement
Neye ihtiyacın var
  1. Pacific Image Electronics CS3600 Motor Replacement, Motor: adım 1, 2 resimden 1. Pacific Image Electronics CS3600 Motor Replacement, Motor: adım 1, 2 resimden 2.
    • To start, open the device by removing the 5, 5mm x 9mm screws, with a Phillips J1 screwdriver.
  2. Pacific Image Electronics CS3600 Motor Replacement: adım 2, 1 resimden 1.
    • Next, remove the 5 9mm x 5mm screws from the circled spots with a Phillips J1 screwdriver.
  3. Pacific Image Electronics CS3600 Motor Replacement: adım 3, 1 resimden 1.
    • Once the screws are removed, carefully lift the motor casing out of the device.
    • The plastic piece circled acts as a clamp, lift the casing up and towards you to detach the casing.
  4. Pacific Image Electronics CS3600 Motor Replacement: adım 4, 2 resimden 1. Pacific Image Electronics CS3600 Motor Replacement: adım 4, 2 resimden 2.
    • Now, with the motor casing in hand, remove the two 9mm x 5mm screw and washer at the top of the motor casing using a J1 screwdriver.
    • Gently pull the motor away from the casing to expose the wires.
  5. Pacific Image Electronics CS3600 Motor Replacement: adım 5, 1 resimden 1.
    • Carefully desolder the wires from their contact point on the circuit board.
    • You have now successfully removed the motor!
Sonuç
Alessia Carlton
201 İtibar
2 adet Kılavuz yazıldı
Ekip
Texas Tech, Team S46-G2, Bennett Spring 2017 Texas Tech, Team S46-G2, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S46G2
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 10
Son 30 gün: 24
Her zaman: 284
