Ana içeriğe geç
Packard Bell 4X4 Desktop Drive Cage Replacement
Neye ihtiyacın var
  1. Packard Bell 4X4 Desktop Drive Cage Replacement, Top Cover: adım 1, 1 resimden 1.
    • Using a Phillips screwdriver, remove the three Phillips head screws (circled in red) from the back of the computer.
  2. Packard Bell 4X4 Desktop Drive Cage Replacement: adım 2, 1 resimden 1.
    • With both hands on each side of the case, slide the top cover toward you. Lift it off the computer.
  3. Packard Bell 4X4 Desktop Drive Cage Replacement: adım 3, 1 resimden 1.
    • The top cover is removed.
  4. Packard Bell 4X4 Desktop Drive Cage Replacement, Drive Cage: adım 4, 1 resimden 1.
    • Remove the two Philips head screws with your Philips screwdriver. You may have to lubricate these screws as they can be very difficult to remove.
  5. Packard Bell 4X4 Desktop Drive Cage Replacement: adım 5, 1 resimden 1.
    • Remove the 1 Philips head screw from the left hand side of the case if there is one. Again, you may need to lubricate this screw.
  6. Packard Bell 4X4 Desktop Drive Cage Replacement: adım 6, 1 resimden 1.
    • Once the screws are removed, disconnect all cables from the optical drive, hard drive and floppy drive.
  7. Packard Bell 4X4 Desktop Drive Cage Replacement: adım 7, 1 resimden 1.
    • Slide the drive cage back. An easy way to do this is the push on the optical drive from the front.
  8. Packard Bell 4X4 Desktop Drive Cage Replacement: adım 8, 1 resimden 1.
    • Lift the drive cage up and out of the computer.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Brandon S
490 İtibar
3 adet Kılavuz yazıldı
Ekip
Packard Bell Planet Packard Bell Planet üyesi
Community
1 Üye
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 13
Her zaman: 1,870
