Ana içeriğe geç
Palm Centro Back Housing Replacement
Neye ihtiyacın var
  1. Palm Centro Back Housing Replacement, Disassembling Palm Centro Battery: adım 1, 2 resimden 1. Palm Centro Back Housing Replacement, Disassembling Palm Centro Battery: adım 1, 2 resimden 2.
    • Press and slide open the battery cover.
  2. Palm Centro Back Housing Replacement: adım 2, 1 resimden 1.
    • Caution: Turn cell phone off before removing battery!
    • Press battery to the right.
    • Then lift up battery pack to remove.
  3. Palm Centro Back Housing Replacement: adım 3, 1 resimden 1.
    • Phone with battery removed
  4. Palm Centro Back Housing Replacement, Back Housing: adım 4, 1 resimden 1.
    • Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
  5. Palm Centro Back Housing Replacement: adım 5, 1 resimden 1.
    • Lift the rubber cap at the top right to reveal the sixth screw.
    • Caution: There is a small Palm sticker under the rubber cap. Tampering with or removing this sticker will void your warranty!
    • Remove the six screws using the T5 Torx screwdriver.
  6. Palm Centro Back Housing Replacement: adım 6, 2 resimden 1. Palm Centro Back Housing Replacement: adım 6, 2 resimden 2.
    • Remove the SIM card so housing can be separated.
  7. Palm Centro Back Housing Replacement: adım 7, 2 resimden 1. Palm Centro Back Housing Replacement: adım 7, 2 resimden 2.
    • Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
  8. Palm Centro Back Housing Replacement: adım 8, 2 resimden 1. Palm Centro Back Housing Replacement: adım 8, 2 resimden 2.
    • Remove the small plastic insert at the bottom of the phone.
  9. Palm Centro Back Housing Replacement: adım 9, 2 resimden 1. Palm Centro Back Housing Replacement: adım 9, 2 resimden 2.
    • Continue with plastic pry tool all the way around the phone to remove the back housing.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Chelsea Barackman
42 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-49, Garner Spring 2010 Cal Poly, Team 15-49, Garner Spring 2010 üyesi
CPSU-GARNER-S10S15G49
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 3,807
